As for thread count, it is a metric bolt. I do not know the metric size but it is close to 1/4x20. That is a quarter inch bolt with coarse threads. And as for the length, it can be too long as the extra length will be behind the mount out of the way.
Quote from: thcrw739 on January 12, 2008, 04:47:57 PMThanks guys,I'll see what i can find at the hardware store..Still not sure on how much length i need to set it to proper hight,I assume at the point right before i feel i need to apply more pressure on the pedal to push it down with my hand...On mine the bolt sticks out about 1/2"-3/4" from the piece with the fixed nut on it that the bolt threads into (that length includes the head of the bolt....which is not included when measuring bolt length.....for example, a 1" long bolt will measure 1" from the tip of the bolt to the bottom of the head).Mine is on a 4 door, so your bracketry may be a little different and require a different length bolt......but as mentioned the clutch pedal is supposed to set just level or slightly higher than the brake pedal....so you should be able to hold the clutch pedal in the approximate position then measure to see how long of a bolt you will need to work.
Quote from: Skyhiranger on January 12, 2008, 08:17:25 PMQuote from: thcrw739 on January 12, 2008, 04:47:57 PMThanks guys,I'll see what i can find at the hardware store..Still not sure on how much length i need to set it to proper hight,I assume at the point right before i feel i need to apply more pressure on the pedal to push it down with my hand...On mine the bolt sticks out about 1/2"-3/4" from the piece with the fixed nut on it that the bolt threads into (that length includes the head of the bolt....which is not included when measuring bolt length.....for example, a 1" long bolt will measure 1" from the tip of the bolt to the bottom of the head).Mine is on a 4 door, so your bracketry may be a little different and require a different length bolt......but as mentioned the clutch pedal is supposed to set just level or slightly higher than the brake pedal....so you should be able to hold the clutch pedal in the approximate position then measure to see how long of a bolt you will need to work.Mine is a 4 door sport..So by your meashurements , sounds like the bolt is only about an inch and a quarter to a inch and a half long?
