Tube front (DONE)
  • 44 Replies
  • 10508 Views
Offline RHodge
  • 523
Tube front (DONE)
« on: January 11, 2008, 01:08:47 PM »
Heres a new bumper I'm working on
should have it done soon ;D
Ryan
« Last Edit: April 12, 2009, 12:11:52 PM by RHodge »
kingzoo
Re: New bumper
« Reply #1 on: January 11, 2008, 04:27:07 PM »
    Nice work so far.I believe in building not buying myself.When I started looking at winch bumpers,I knew real quick that building my own was a must.With shipping included bumpers were running $650 and up,and I can build one for less than half of that.
Offline ToyYoda
  • 226
Re: New bumper
« Reply #2 on: January 18, 2008, 09:34:42 AM »
Simple & clean looking, plus looks like it can take a hit. Nice job so far! 8)
Offline RHodge
  • 523
Re: New bumper
« Reply #3 on: January 18, 2008, 11:17:36 AM »
thanks
Offline v-stone
  • 625
Re: New bumper
« Reply #4 on: January 21, 2008, 08:56:04 PM »
Thanks for sharing. Are you going to weld it to the frame or bolt on.
Looks good.
SAS Tracker! No looking back now.
Offline RHodge
  • 523
Re: New bumper
« Reply #5 on: January 22, 2008, 06:53:04 PM »
It will bolt Im makeing the side plates that will bole to the four holes on the end of the frame them I will drill a few holes in the tube to bolt to
I'll take some pic when I'm done
Ryan
Offline RHodge
  • 523
Re: New bumper
« Reply #6 on: February 23, 2008, 07:42:09 PM »
worked on the bumper this afternoon, it coming alone
This is under the front were it wraps around the cross tube (kinda hard to see)
Offline RHodge
  • 523
Re: New bumper/Tube front
« Reply #7 on: April 18, 2008, 05:53:12 PM »
well after looking |removethispart|@ the pic of my ride I decided it looked like sh :o    so I'm going to build a tub front end also. got the new battery box build and the winch mounted, gona start bending some tub tomorrow
Later
Ryan
Offline Element
  • 1902
  • LillyKicker
« Reply #8 on: May 24, 2008, 10:12:50 PM »
Any update????
zUkTAH
U4WDA
Offline RHodge
  • 523
« Reply #9 on: May 26, 2008, 04:40:00 PM »
no  >:( Iv been working on other stuff, I hade to finnish the  remodel of  my bathroom and making a bumper for a frends sami
but I did finish the nissan box on it
Offline RHodge
  • 523
« Reply #10 on: July 08, 2008, 08:50:38 PM »
I got some time to work on my tube front here is a few pics
Still have a ways to go
« Reply #11 on: July 15, 2008, 01:11:16 PM »
Looks good, on your front winch mount you can get four inside frame inserts from trail tough that make things real strong for winching, I have put them on several rigs and they are real solid and weld to the in side of the 2x4 front frame rails, if you tear them out you would have some other real issues.
« Reply #12 on: July 15, 2008, 02:17:50 PM »
 ;) Nice work! Like your flaming creeper.
Offline RHodge
  • 523
« Reply #13 on: July 16, 2008, 08:03:27 PM »
After much thought I decited to weld the winch plate on instade of bolting it
I plated inside the frame then caped itI'm also going to make a gusset
Here's a better shot of the back where it wraps around the tube
I don't think is going anywhere  :)
Did some work on the stinger too
Later Ryan
« Reply #14 on: July 16, 2008, 11:32:34 PM »
Looks good, I did an arb bumper like that once, got rid of the u bolts and used a couple of 1/2 inch bolts and slid a piece of heavy wall pipe into the tube part of the frame and spot welded it to a couple of holes that were put in the tube before sliding the pipe in, it has worked out well with heavy winching.
