driveing/spotlights
  • 1071 Views
hanny01
driveing/spotlights
« on: January 10, 2008, 08:35:22 PM »
trying to find the wire to hook up the high beam switching. i understand the earth switching side of things.
can anybody point me to a thread.
1998 v6 australian grand vitara 2.5 ltr
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: driveing/spotlights
« Reply #1 on: January 11, 2008, 07:44:54 AM »
This is the schematic for an '02 XL-7 (manufactured in Japan).  No clue if it will help or not...
XL-7 front coils
1.5" rear coil spacers
Offline Rally_T-115
  • 117
« Reply #2 on: January 11, 2008, 06:34:06 PM »
Just wired up my rally lights on my 99 GV.  One of the wires is WHITE, the other is red with a white stripe.  Unfortunately I don't remember which is which as I type this.  The wiring diagram is at work.
I think that white is positive power to the headlamp bulb all the time, and the red/white wire is the negative for the high beams (as long as the high beam switch is on).  I'm fairly certain but again I don't have the diagrams in front of me even though I just finished my lights 2 nights ago.  (Aimed them last night, love them!)
James
1999 Suzuki Grand Vitara.
No lift or bigger tires intended.
Warn hubs. Air-SOTF circumvented.
Aftermarket4x4 front skid & fuel tank skid.  RRO Rockrails.
Waiting for: trans crossmember upgrade & skid. Contemplating: ARB rear locker.
Offline IanL
  • 466
« Reply #3 on: January 12, 2008, 01:01:36 AM »
According to my '98 GV Service Manual (jp built vehicles):
RH supply - White/red
LH supply - White/blue
High beam ground via switch & Headlight Relay No. 1 - Red
Low beam ground via switch & Headlight Relay No. 1 - Red/white
Offline Rally_T-115
  • 117
« Reply #4 on: January 12, 2008, 08:12:28 AM »
Yep that's it!   ;)  I remember now.  I used the wiring for the right-side headlamp to trigger the relays for the rally lights since it's closer to the battery.
James
