Lowering my T-case
  • 12 Replies
  • 1956 Views
J-Ron
Lowering my T-case
« on: January 09, 2008, 08:23:56 AM »
so my front driveshaft won't work due to the angle, my rear shaft vibrates violently since i can't match the angle on both sides. my next step is to find a way to lower my transfer case on my 88 samurai. does anyone know of any kits or fixes that i could use to do this?
Offline SnoFalls
  • 1358
Re: Lowering my T-case
« Reply #1 on: January 09, 2008, 09:08:35 AM »
how much lower does it need to go?
would a custom mount/brace do it?
could could always also run a carden.
bruce5385
« Reply #2 on: January 09, 2008, 08:56:14 PM »
I cut the mounts off the frame and lowered my t case 3 inches.  you have to add some square tubing to the frame to fill in the gap that you create.  ill try to put pic on tomm.
dicedaniels
« Reply #3 on: January 09, 2008, 09:35:07 PM »
what did you do for the driveline between the t-case and tranny?
Offline ROSS
  • 1412
« Reply #4 on: January 09, 2008, 10:06:40 PM »
how much lift you got??  i've got about 5 1/2 never had a bit of a problem
bruce5385
« Reply #5 on: January 10, 2008, 05:59:19 PM »
used the stock intermediat shaft but it is maxed out.  really not for everyday use.  only suggest it for an off road truck/sammy.  let me go take pics
dicedaniels
« Reply #6 on: January 10, 2008, 07:54:38 PM »
i was wonderng the same thing. from the little pic it looks pretty nice though.
bruce5385
« Reply #7 on: January 11, 2008, 06:45:10 AM »
camera broke try to get pics up loaded soon.
J-Ron
« Reply #8 on: January 11, 2008, 04:01:30 PM »
so im running toyota axles with 3" lifted springs. it's about an 8 1/2" lift. i can't run a cardon shaft cause the diff is centered.
so it seems that im going to need to cut and lower the mounts?
 and the driveshaft from the transmission to the t-case will be able to handle the new angles?
bruce5385
« Reply #9 on: January 11, 2008, 07:28:31 PM »
up to 3 inches.  3 inches is max not recomended for on road use.
J-Ron
« Reply #10 on: January 13, 2008, 02:43:58 PM »
are you still trying to get those pics up? i'd love to see them
bruce5385
« Reply #11 on: January 14, 2008, 05:50:56 PM »
tried to add pics says they are to big any other way to upload them??
Offline museboy07
  • 641
« Reply #12 on: January 14, 2008, 06:23:24 PM »
if the pics are too big copy and paste them into the "paint" program under accessories.  Up at the top there's a tab...i think its file or something but then there will be a "resize" option.  After you make it smaller then save it and upload it.
