Sway Bar Mod for 2d Gen 02 Tracker Coil Lift
  • 22 Replies
  • 5456 Views
Offline bzzr2
  • 1011
Re: Sway Bar Mod for 2d Gen 02 Tracker Coil Lift
« Reply #15 on: February 13, 2008, 01:11:38 PM »
more uptravel isn't going to get you any farther, so if you don't plan on installing drop brackets and adding taller springs to your spacers you might as well just drive it like it is until your springs start to sag, which they will soon enough if you do enough rough driving!  enjoy!
09 taco reg cab short box 4x4
nprecon
« Reply #16 on: February 13, 2008, 06:58:55 PM »
I'm not aware of anyone who is currently making or offering a set of springs for these things that will provide an honestl 2 or 2 1/2 inches of lift anyway.  So even if I go with longer springs, I'd still end up having to slide in a 1/2 inch or inch shim to push it to where it sits now.  If I went with longer springs and the smaller shim, I would probably pull off the sway bar and allow the arms to compress and flex easier.   Then again, if worms owned machineguns... those damned birds wouldn't screw with them so much either.  It's probably just as good they don't.
Offline IanL
  • 466
« Reply #17 on: February 14, 2008, 12:19:21 AM »
....   I might even opt for an OME spring set.
That, you will not regret.
nprecon
« Reply #18 on: February 14, 2008, 04:43:46 PM »
Which one would i not regret Ian, 1. not arming worms with machineguns.... or 2. pulling the coil spacers and installing longer springs and removing my sway bar?
Offline IanL
  • 466
« Reply #19 on: February 15, 2008, 01:04:02 AM »
Opting for OME, as I said in the quote  ;)
oilstained
« Reply #20 on: February 15, 2008, 07:42:03 AM »
XJ coil measures: 17" tall, 5" dia. and uses 0.475" dia. wire
TJ coil measures: 18.5" tall, 5.25" dia. and uses 0.575" dia. wire
95 Aerostar coil measures:13.625" tall, 6.5" dia. and uses 0.600" dia. wire
2dr Kick rear measures: 12.5" tall, 4.25" dia. and uses 0.460" dia. wire
2dr Kick front measures: 10.875" tall, 4.375" dia. and uses 0.600" dia. wire
i got me a set of used xj springs off ebay for like $25 and it gave me another inch or so over the calmini springs, and the xj's can take a heavier load, for when ya load up for moab.
Offline Jeff@TireBalls
  • 559
« Reply #21 on: February 15, 2008, 03:20:08 PM »
Did you use them on the front or rear?
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Offline epike7915
  • 88
  • Team Kamikaze 4x4
« Reply #22 on: August 14, 2008, 08:26:05 PM »
X2
TEAM KAMIKAZE 4x4:
88 Zuk-"LOCKJAW" 1.6 16v, Waggy D44's w/5.38's and full spools (ft & rr), 37" Iroks w/beadlocks, 6.5 to 1 T-case.  Full hydro steering coming soon.  Eternal work-in-progress!
Daily Driver: 2000 Tracker 4x4 w/ 2.0 4 cyl. & 5 speed. (How long will it stay stock??)
