high oil pressure
  • 1133 Views
zooking
high oil pressure
« on: December 16, 2007, 10:15:52 PM »
hi guys,
my v-6 2.5 is running oil pressure of 80 to 90 psi and thats at idle!!
i feel its too high,,am i right  and i there a common cause in our engines??
cheers todd
Re: high oil pressure
« Reply #1 on: December 24, 2007, 05:05:15 PM »
First thing i thought of is restrictive /Defective oil filter. I personaly have had more than 5 defective oil filters in the past 5 years. most were motorcycle, but 2 were automotive... I would change the oil filter asap, just to be sure. I had a oil filter colaspe Inside before.....
Offline IanL
  • 466
« Reply #2 on: December 25, 2007, 01:04:12 AM »
Buy the manufacturer's oil filter.  Cheap filters are, well, cheap.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #3 on: December 27, 2007, 07:04:41 AM »
Buy a OEM or WIX or K&N Thats way to high of a oil pressure idle should be 12-20 i think im not sure. If thats the base 1 filter may be plugged up or a passage 2 your pressure relief valve is gummed up in the oil pump.Change the filter and oil and report back to us.
Josh
01 GRAND VITARA
