Samurai/GTi engine radiator lines
  • 1396 Views
locost7018
« on: December 16, 2007, 04:53:45 PM »
To the Samurai people on this list. How did you get the coolant lines from the rear of the GTi engine to the radiator? Did you just use a rubber "U" bend or something fancier like cast ali. elbows, etc.? Russ
luvmysammy
Re: Samurai/GTi engine radiator lines
« Reply #1 on: December 16, 2007, 05:05:16 PM »
should post pics of what ur needing help with, thanks, Matt
locost7018
« Reply #2 on: December 16, 2007, 07:29:26 PM »
It would be a long while before I could post pic's. On a GTi engine in a rear drive application the water in and out are at the rear of the engine and need to turn 180deg to go to a front mounted radiator. I thought, maybe, the Samurai guys maybe used some of the parts from their old engine to turn them around. I have never seen a Samurai engine to see how they are plumbed. I have a GTi engine and a Samurai trans that I am using in a non Suzuki car called a Locost. It is a Lotus 7 replica. Russ
