zuktoy (going slowly more for you to see)
  • 1712 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: December 15, 2007, 03:49:50 PM »
ok if your not up to speed on zuktoy do a surch you will get all the posts. itsg going slow even though im putting in about 20 hours a week but hear is what ive been doing. ive straightened the frame and put in the gussets for the removable lower front links and tranny cross member carriage. i welded gussets int the frame got pix thy are better than explanation.
Offline wezzlegod
  • 227
Re: zuktoy (going slowly more for you to see)
« Reply #1 on: December 15, 2007, 03:51:47 PM »
more
Offline wezzlegod
  • 227
« Reply #2 on: December 15, 2007, 03:54:04 PM »
now i decided to strengthen the fount of the frame for a strong bumper and wench. a must because of the crush section of the frame. also in changing the body mount in the front to open it up for direct rock placement to tire. :P
« Last Edit: December 15, 2007, 03:56:31 PM by wezzlegod »
Offline wezzlegod
  • 227
« Reply #3 on: December 15, 2007, 03:59:08 PM »
i didnt finish the front body mount yet i will do it tomorrow.
kingzoo
« Reply #4 on: December 15, 2007, 04:02:23 PM »
   Looking good.keep up the good work and the photos.
Offline wezzlegod
  • 227
« Reply #5 on: December 15, 2007, 04:03:29 PM »
on buy the way got pix of f Axel for you.
