lost and looking
  • 1423 Views
jd1111
lost and looking
« on: December 09, 2007, 08:32:34 PM »
hey i looked all over for springs to lift my tracker CANT FIND NONE  :P :P  i think i can build spacers out of steel just dont know if i need a recess for spring to ride in i got dim 4.5/ 2.5/2 if u help with eather i woeld be greatfull
kingzoo
Re: lost and looking
« Reply #1 on: December 09, 2007, 08:34:53 PM »
    Ome makes a lift kit consisting of springs,struts and shocks.calmimi also makes both a 2 inch and 3 inch lift kit.All 3 are good products,but I prefer the OME lift kit.It only gives 1.5 - 2 inches of lift,but it rides and handles better than any kit out there.
jd1111
« Reply #2 on: December 09, 2007, 08:38:18 PM »
what size tires
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #3 on: December 09, 2007, 08:42:11 PM »
The OME kit doesn't come with tires, you have to buy your own. If you want to run 33's with just the OME kit some minor fender trimming will be required. ;)
Student of Now Master of Then
kingzoo
« Reply #4 on: December 09, 2007, 08:45:22 PM »
   The OME kit will run 235 tires with no problem.30 inch tires will rub at full compression.If you want to run 30-31 inch tires the 3 inch Calmini allows 30's with no problem.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #5 on: December 10, 2007, 02:27:29 PM »
This link will give you a lot of information:
http://www.zukiworld.com/forum/index.php?action=search2  Just type in "tracker lift"
http://rocky-road.com/kicksus.html
1993 4-door Sidekick
4.24:1 t-case
