headlight adjustment on 91 4 door Sidekick
  • 2564 Views
kingzoo
« on: December 08, 2007, 06:12:24 PM »
    How do you adjust these headlights?There is no under hood adjustment,and no holes in grill around headlights to make adjustment.I drove in bad fog tonight,and my drivers side headlight is popinting at the ditch on the passengers side,and the passenger side is pointing high and left.
  My manual says no adjustment is available,but there has to be a way.
  Everything is solid with no damage,bulbs are tight,everything works proper,just out of aim.
kingzoo
Re: headlight adjustment on 91 4 door Sidekick
« Reply #1 on: December 09, 2007, 08:36:39 AM »
   Nobody knows?
Nine Pine
« Reply #2 on: December 09, 2007, 09:37:06 AM »
Here is a link to the aiming instructions for your vehicle. Hope this helps.
http://www.autozone.com/az/cds/en_us/0900823d/80/1e/06/fb/0900823d801e06fb/repairInfoPages.htm
The aiming procedure starts just below half way down (it is a long webpage), so you will have to scroll down quite a bit.
Sincerely,
Nine Pine
kingzoo
« Reply #3 on: December 09, 2007, 08:48:18 PM »
   I allready have that info,but I do not have any adjusters where they stated.
  I can find no adjustment anywhere at all.I oulled the grill today and there is still no adjustment points that I can find.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #4 on: December 10, 2007, 08:06:33 AM »
I don't have stock headlights anymore, so i can't check for you on the adjusters.  Normally there would be small screws or 8mm head bolts coming from the back of the headlight that would be rotated to adjust up and down, and left to right, but a lot of composite headlights don't have adjustment.
Actually, i take all that back.  I just remembered that the adjustment is from the front.  There are screws (that strip out easily) that are hooked into a plastic clip thingy.  They're on the upper inside corner of each light, and i think i used to be able to adjust them with the grille in place.  The plastic pieces have been notorious for stripping, and not allowing the adjustment.
1993 4-door Sidekick
4.24:1 t-case
