http://Car-Part.com makes a great parts interchange guide. just look at the part you want then click years at the top of the listing, all the years that fit will be listed in order.
Here is a list.....it is simply designed to tell you what ratio you have based on year, body, engine, and tranny.89-98 Trackick gear ratiosYear 2 or 4 door Engine type Transmission Axle ratio89 2 1.3L carb. 5 speed man. 5.62589-95 2 1.6L TBI 5 speed man. 5.12589-95 2 1.6L TBI 3 speed auto 4.62591 4 1.6L TBI 5 speed man. 5.37592-98 4 1.6L MPFI 5 speed man. 5.12592-98 4 1.6L MPFI 3 speed auto 4.3092-98 4 1.6L MPFI 4 speed auto 5.12594-98 2 1.6L MPFI 5 speed man. 5.12594-98 2 1.6L MPFI 3 speed auto 4.3094-98 2 1.6L MPFI 4 speed auto 5.12596-98 X90 1.6L MPFI auto or man. 4.6254.625 gears have an 8/37 tooth count4.30 gears have a 10/43 tooth count5.125 gears have an 8/41 tooth count5.375 gears have an 8/43 tooth count5.625 gears have an 8/45 tooth count
I can verify the whole list is accurate, because I have personally seen, had, or pulled every ratio, and every combo, on the list, except for the 89 1.3L 5.625s (but I know that one is correct).
I agree that list is accurate, but missing one ...91 4 1.6L TBI 3 speed auto 4.625
Quote from: Skyhiranger on December 04, 2007, 08:05:03 AMHere is a list.....it is simply designed to tell you what ratio you have based on year, body, engine, and tranny.89-98 Trackick gear ratiosYear 2 or 4 door Engine type Transmission Axle ratio89 2 1.3L carb. 5 speed man. 5.62589-95 2 1.6L TBI 5 speed man. 5.12589-95 2 1.6L TBI 3 speed auto 4.62591 4 1.6L TBI 5 speed man. 5.37592-98 4 1.6L MPFI 5 speed man. 5.12592-98 4 1.6L MPFI 3 speed auto 4.3092-98 4 1.6L MPFI 4 speed auto 5.12594-98 2 1.6L MPFI 5 speed man. 5.12594-98 2 1.6L MPFI 3 speed auto 4.3094-98 2 1.6L MPFI 4 speed auto 5.12596-98 X90 1.6L MPFI auto or man. 4.6254.625 gears have an 8/37 tooth count4.30 gears have a 10/43 tooth count5.125 gears have an 8/41 tooth count5.375 gears have an 8/43 tooth count5.625 gears have an 8/45 tooth countI agree that list is accurate, but missing one ...91 4 1.6L TBI 3 speed auto 4.625
I am waiting to hear back on that one. I just recently found someone that actually has a 91 4 door with an auto (until now, I though all 91, 4 doors had manual trannys). I think the 91, 4 door, with auto will have 5.375s (5.38s), like the 5 speed.Or are you 100% positive that a 91, 4 door, 1.6L TBI, 3 speed auto will have 4.625s?
Quote from: Skyhiranger on December 04, 2007, 01:29:52 PMI am waiting to hear back on that one. I just recently found someone that actually has a 91 4 door with an auto (until now, I though all 91, 4 doors had manual trannys). I think the 91, 4 door, with auto will have 5.375s (5.38s), like the 5 speed.Or are you 100% positive that a 91, 4 door, 1.6L TBI, 3 speed auto will have 4.625s? I own one, it's my parts rig. ... it certainly doesn't have 5.38's
dropped the front third and sold it off as a 4.62 ... no complaint from the customer. when the weather gets nicer here, I'll go rotate the rear and take a count.it's 4.62 tho I'm 99% certain ... I drove it and can kinda "tell".
If we are using carparts.com as the basis of this search. Then 5:38's came in 1989, 1990, and 1991 suzuki sidekick models. My personal references for my information are from Petroworks, Trail Tough, and Rancho recyclers. I have had to purchase more than just one of them before. I stand by my previous comment of the 5:38 gears offered for more than one year.
If they came in 89 and 90 sidekicks......what body style and drivetrain set up did they come in?
