The inner and outer CVs are of the
same type construction, the difference
being the inner CV has the cup, which is
the limiting factor.
The mod will require cutting and welding
a fixed flange onto the axle to bolt the CVs
up to, The left (drivers in US) side has a flange,
and will work fine for the mod, the short stubby
axle will need the hack, weld treatment, tho
this should be no problem, there have been several
welded axles, I having one of them, on this forum
with no problems as to date.
The second half of this mod requires the cutting
of the spline/shaft off of the outer CV and a flange
welded there too, these two flanges will now get
bolted together.
