Trak breaks to a Samurai?
  • 1105 Views
87 sammi
« on: October 16, 2007, 07:28:44 PM »
I just bought a 97 trak with a 1.6 in it to do the swap to my 87 samurai and i want to use as many parts off it as i can. Does anyone know it the breaks ( calipers, drums, rotors...) will match up on my Zuk axles??
THanks All!!
DistantSmoke
Re: Trak breaks to a Samurai?
« Reply #1 on: October 24, 2007, 04:11:51 PM »
I tried the calipers from a 89 tracker onto an 87 sami front and they do not fit. the bolt holes would line up if the caliper didn't bottom out on the top of the knuckle first.
« Reply #2 on: October 26, 2007, 07:18:11 AM »
I'm doing it right now.  4dr Kick fronts on the Sammy.  They fit, but come real close to the king pin bolts.  Also, I had to remove  good deal of material from my hi-steer arms to make it work, and do a slight bit of grinding to the caliper.
Others are running Kick brake upgrades without problems.  If you run Sammy calipers in the rear, this helps get proportioning bacj=k
