KYB GRS-2 struts longer than stock?
  • 10 Replies
  • 3175 Views
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« on: October 03, 2007, 06:23:21 PM »
are the KYB GRS-2 struts longer than stock?  I just put a new set in and they seem longer as far as the travel?  anyone know.  I had to take out my strut mount spacers as the strut would fall out of my strut extenders.  This happened when I tested on my flex rocks in the backyard.
Offline museboy07
  • 641
Re: KYB GRS-2 struts longer than stock?
« Reply #1 on: October 03, 2007, 06:48:11 PM »
When i bought mine they looked to be the same length...weird
Offline john1974
  • 617
    • Zuknation
« Reply #2 on: October 03, 2007, 07:03:35 PM »
they probally are the same, but maybe the travel is different.
« Reply #3 on: October 04, 2007, 04:58:12 AM »
I compared my side my side with stock.  Exactly the same.  Smooth riding though, well valved.
Offline jeff1997
  • 1228
  • 27
« Reply #4 on: October 04, 2007, 06:16:22 PM »
Mine were exactly the same on my 97 Sport.
3" Masterkit1 body lift
Custom strut spacers
Cuthulu
« Reply #5 on: October 04, 2007, 09:44:11 PM »
I emailed KYB and asked if they had longer struts for trackicks and they said that they did not.  They did give me the part number for 50MM longer shocks if you want that.
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #6 on: October 05, 2007, 03:57:40 PM »
Ok I'll bite, What is the part number and what vehicle is it made for?
Student of Now Master of Then
Offline john1974
  • 617
    • Zuknation
« Reply #7 on: October 06, 2007, 03:52:58 AM »
ya I didnt need the part number.  I just put these struts in :)
Cuthulu
« Reply #8 on: October 06, 2007, 08:16:49 PM »
Here is the response I got from KYB on the shocks.
The part number for the rear is 344371, it is much firmer but it has the
same mounts as the shocks you have now and should work with your lift.
Thank you,
Dan
KYB America LLC
So there you have it.
Cheers
  • 416
  • Lil Suzys Dad
« Reply #9 on: October 08, 2007, 11:59:03 AM »
Thank you,
Dan
KYB America LLC
Cheers
These are from a Ford Econoline E250 1992-04. I am not sure these would be the best choice for a kick. Since these fit the rear there are tons of choices. I have Rancho 5000 Ford F150 shocks on lil Suzy and I understand Crown Vic shocks work as well.
« Reply #10 on: October 09, 2007, 09:06:33 AM »
I'm thinking about swapping back to a stock shock and just relocating the mounting bracket on the rear axle.  The rear is still a bit stiffer then I like.
