I assume your talking about the diff gears. Yes but only 2 front ring and pinion from a tracker/sidekick will bolt into the samurai. May I add its a very good mod for sammy I have done it on my 87 I sold off.I hope I didn't screw up, I haven't been able to access this site for two days now so I went ahead and bid on these. They are 4.62 ring & pinion gears from a sidekick/tracker front. Quote from: mrfuelish on September 20, 2007, 10:20:22 AMyep, 1995 or older for the front splines to match(22) and say 1996 and newer for the rear splines to match(26)drill the flang holes on the rear four times (could be smaller or larger pattern needed) and there ya go. So your saying I have to drill the diff. holes out for the ring gear? I also read somewhere that I will need spacers for the ring gear??
What are the benefits? Are they beefier or/and is it a different ratio than the sami's? Really curious!
