HELP!! must lower!
  • 1741 Views
Offline bandit86
  • 1641
  • elv8rguy
HELP!! must lower!
« on: September 09, 2007, 08:58:08 PM »
friend is using a tracker frame for a kit car, needs to lower it.  I  heard of firebird front struts, anyone know anything else?  wont need a lot od suspension travel, the strut tower will be cut  and lowered, just need a short strut
Re: HELP!! must lower!
« Reply #1 on: September 09, 2007, 10:07:03 PM »
Don't have a clue on how to lower one
But pics of the kit car project would be interesting.
« Reply #2 on: September 10, 2007, 05:25:09 AM »
If you don't need so much travel can't you just shorten the springs and add limiting straps to stop the front struts over extending (and letting the springs fall out!).
Offline bandit86
  • 1641
  • elv8rguy
« Reply #3 on: September 10, 2007, 07:11:08 PM »
the strut towers hit the hood, need shorter struts so the strut tower can be lowered for clearance
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #4 on: September 10, 2007, 07:55:39 PM »
How far does it need to be cut?
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: September 11, 2007, 06:06:55 PM »
4 inches shorter would be nice, take what we can get at this point
« Reply #6 on: September 11, 2007, 07:10:08 PM »
If you want to do the work you could just eliminate the struts all together.  Do a setup similar to Mike Haggens front end.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #7 on: September 12, 2007, 10:10:43 AM »
what did he do??
« Reply #8 on: September 12, 2007, 06:30:30 PM »
http://www.zukiworld.com/month_050106/feature_hagen-newfrontend.htm
Redesigned the front end and eliminated the struts.  Then you could put some mini-truck shocks on or something.
