93 Sidekick 16V idle issue
  • 1530 Views
« on: September 08, 2007, 08:29:02 PM »
Here is a fun one for you.  At idle it drops a couple of cylinders.  Like... 2-4.  Doesn't like reving up really high either.  Just picked this car up, the previous owner rebuilt the head and replaced the filter and fuel pump.
Any ideas?
Re: 93 Sidekick 16V idle issue
« Reply #1 on: September 08, 2007, 11:01:20 PM »
could have the plug wires on wrong, the book is, could have gotten dirt in the injectors if the screens are rusted.
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #2 on: September 10, 2007, 10:53:06 AM »
Do a search on 16v and check zuwharrie.  The disty rotates counter clockwise.  Check the simple and free things first.
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #3 on: September 10, 2007, 06:37:58 PM »
There's also an idle adjuster screw on the throttle body, sometimes turning it 1/4 turn(or less) clockwise can help. Mke sure to mark it before you move it, just in case you need to move it back.
« Reply #4 on: September 12, 2007, 05:24:22 PM »
Timing is right, plugs are right.  Looking at either injectors or computer.
The Computer doesn't have the cap issue, already checked that.  Sadly, I really want a Noid kit so I can check the injectors easily...  Anyone know a good way to test them without tearing the intake manifold apart?
« Reply #5 on: September 12, 2007, 05:45:12 PM »
Not really, you might just have to take half of it apart, you could call trail tough and ask Brent.
« Reply #6 on: September 12, 2007, 06:26:02 PM »
Took it apart.  Two of the injectors fail to go click when you hit them with 12v.  Guess I call Hawk Suzuki tomorrow and get some more since the parts stores are 5 days out on replacements.  :)
