Replacing passenger side axle seal?
  • 9 Replies
  • 1936 Views
Offline Jeff@TireBalls
  • 559
« on: September 05, 2007, 05:43:34 AM »
Does anyone know of a trick to getting the passenger side CV out without removing the strut and messing up the alignment? I need to replace the axle seal.
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Re: Replacing passenger side axle seal?
« Reply #1 on: September 05, 2007, 07:20:38 AM »
That is the trick.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #2 on: September 05, 2007, 07:38:36 AM »
You can do it by leaveing the spindle and the strut attached its hard tho. But first things first grab ur axle is it loose in the carrie if it is changing the seal is pointless
01 GRAND VITARA
  • 559
« Reply #3 on: September 05, 2007, 07:50:45 AM »
So what makes it loose? Is not supported by a bearing.
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: September 05, 2007, 09:59:38 AM »
There is no camber adjustment on the GV's unless you've added it.  So removeing the strut shouldn't change anything.  If you do have camber bolt or something else you could split the ball joint :-X
George
  • 559
« Reply #5 on: September 05, 2007, 10:32:43 AM »
I slotted the strut holes when I did the lift. Looks like the ball joint split may be the way to go.
Offline ngrover
  • 131
« Reply #6 on: September 07, 2007, 07:41:18 PM »
Interesting, my seal is leaking and I just tried what you said, grabbing the axle and checking for slop... sure enough it seems a bit loose. What do I need to fix that? A bearing?
2000 Suzuki Grand Vitara, 5spd. 2.5 inch lift, 225/75R16 AT's
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #7 on: September 07, 2007, 08:10:02 PM »
BTW, I just had this seal done when I got my 5.12 gears installed.  There are two OEM Suzuki part numbers for that seal:
09283-35008 was the original design, and has been superceded by the new part #09283-35052.  I would try to get the newer design.  I'm assuming it is improved versus the old design.  Good luck.
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Offline ngrover
  • 131
« Reply #8 on: September 07, 2007, 09:24:09 PM »
Brilliant man thanks... that helps. I went to the local parts store and had a hard time explaining what seal I needed (I think the dude was a little slow). Now I can just go to the suzuki dealer and give them a part number.
I'm still wondering if a bit of play is normal and if I need more than just a seal?
Thanks
  • 559
« Reply #9 on: September 08, 2007, 06:05:50 AM »
The auto parts stores list it as an inner wheel seal.
