please help need to replace clutch cable
  • 11 Replies
  • 2233 Views
opera936
« on: September 02, 2007, 04:05:15 PM »
i'm new to this forum in hope of search for repair/mantain techniques for my 96 4dr sidekick 5spd manual sports.  i recently got this car from a friend and i was told that the clutch cable is disengaged from the transmission.  there's no pressure against the pedal or whatsoever whenever i depress the clutch.  once its fully depressed it won't bounce back.  so i decided to repllace the clutch cable, but i can't seem to locate such a cable in/out side of the firewall.  any help would be greatly appreciated.  thanks. :)
http://www.uploadhouse.com/fileuploads/435/4359610dc3f00ff3425d1841368ebfcee2c4f6.jpg
http://www.uploadhouse.com/fileuploads/435/4359600331b852c5ae3c8bd5c81e315b90d637.jpg
http://www.uploadhouse.com/fileuploads/435/435959b67d0cd1eb46df28f413f17a4dbe6d3b.jpg
http://www.uploadhouse.com/fileuploads/435/435958017bf9a7e7d56b79980ea3541037b720.jpg
trashers delight
Re: please help need to replace clutch cable
« Reply #1 on: September 02, 2007, 09:41:17 PM »
go under your stearing column find where the cable runs through the fire wall take something stiff n long like a coat hanger poke it through a good ways thats then go look where it poked out. or go buy a hainse manual from auto zone. it should be near the top of the fire wall under yer hood on the right or left if your not in the states
Offline KickTurn
  • 53
  • My wife likes the smell of petroleum products.
« Reply #2 on: September 03, 2007, 10:03:51 AM »
It's just possible that the cable is just unhooked from the pedal linkage, so check that first.  Another possibility is that the free play adjusting nut is not on the other end of the cable at the clutch linkage.  If it's either of those two things, slide the cable back and forth in the sleeve some-- this will be a good opportunity to see if the cable is sticky or damaged and needs replacing.
95 Kick JLX 4x4 4dr 1.6 16v.
235s, manual hubs.
opera936
« Reply #3 on: September 03, 2007, 07:19:47 PM »
hi i went under the driver's seat(inside) and checked there were no cables but some sort of pump .  i'm thinking my clutch is not linked by a cable but by some sort of pump linkage?  thanks
« Reply #4 on: September 03, 2007, 09:14:17 PM »
There is no cable on a sport, it's hydrolic.
opera936
« Reply #5 on: September 04, 2007, 07:35:10 PM »
please help me out i realli want to fix this problem.  so if it's not an cable is it possible to fix the hydrolic linkage without taking it to the shop?
« Reply #6 on: September 04, 2007, 10:19:25 PM »
Yes it all just unbolts from the out side of the trans so it is not that hard at all, could be out of fluid or the master looking thing by the pedal could be shot if no fluid is leaked out, just replace it, call hawk and have him send you a used one if on a buget.
opera936
« Reply #7 on: September 05, 2007, 07:18:32 PM »
so wut i have to do now is to unbolt the hydrolic connection on the transmission and replace it with a new one?  if so  how am i suppose to do that?  thanks again.
« Reply #8 on: September 05, 2007, 09:16:33 PM »
did ya pull the boot back on it and see fluid leaking? did it have fluid in the res.? is there fluid leaking down the inside of your fire wall?
opera936
« Reply #9 on: September 06, 2007, 07:05:01 PM »
i know this may sound silly but could u instruct me on how to check those equipments.  i appreciate it.
opera936
« Reply #10 on: September 06, 2007, 08:05:33 PM »
please note that the clutch cable on my sidekick is not placed like the one in the picture.  the cable on that picture is not existent on my sidekick.
opera936
« Reply #11 on: September 07, 2007, 08:57:30 PM »
please help me out with this problem ::)  where do i start?
