hi everyone! need some advice...i'm running a 88 samy on 31's and stock gears,i have lost the use of my 5th gears,i'm looking to buy t-case gears but confuse about wich ratio to get,my sammy is mostly used for off roading,rockcrawling,little mud,and highway to get to the bush...i was thinking about the 5.14:1 or will the 6.1:1 would be better i hate havin to go downhill on my brake!,but don't want to be shifting in the midle of the hill either!
2nd; i'm still running my 1.3 motor(its getting tired)i can get my hand on a 1.6 8v,should i keep the carb set up or should i switch over to fi? i will be puting a cam and header.so power wise wich set up would be better: 1.6 with a aftermarket carb,cam and header or cam and header on fi? thanks for any feedback!
