reply quick! Front and rear diff the same?
  • 1142 Views
ls7colorado
« on: August 30, 2007, 11:11:39 AM »
I am wondering if the front and rear diffs are the same on my samurai, I just installed lockrights in booth axles but I put the front spider gears in the rear and the rear spider gears in the front and the axle shafts wont slide in now. If I put the front diff in the rear and the rear in the front would it work?
Offline chet
  • 556
  • Zuki time!
Re: reply quick! Front and rear diff the same?
« Reply #1 on: August 30, 2007, 11:13:21 AM »
yes the only difference is the sidegears
ls7colorado
« Reply #2 on: August 30, 2007, 11:52:20 AM »
sweet thanks alot
« Reply #3 on: August 30, 2007, 04:47:15 PM »
The later samurai's also had 2 pin carriers in the front, instead of 4 pin.....the 2 pins started in either 88.5 or 90, can't remember which.
