Replacing the Battery
  • 1510 Views
Lisa
« on: August 29, 2007, 03:32:34 PM »
I have a 2002 Gand Vitari XL 7
I travel alot
The battery was going bac
I had it replaced and now I am helpless
The SUV will start but dies almost immediately
I have been told to hold the gas down and run it and it will straighen out
I have been told to take the battery post from battery and hold for 30 seconds
and now I am trying disconnecting battery for 24 hours and that will clear the problem
I am still waiting on the 24 hours to see if that works
Any suggestions would be great!
Thanks
Lisa
Offline benzr2
  • 72
Re: Replacing the Battery
« Reply #1 on: August 29, 2007, 04:04:15 PM »
Are you sure the battery is the problem, is the air filter clean?
2001 Tracker ZR2 235/75/15 ATs       1987 Samurai Tin Top     New Project!!
Lisa
« Reply #2 on: August 29, 2007, 04:21:16 PM »
Never had a problem till I replaced the battery.....
Do you think that computer reprogram sounds like the right direction?
I will check air filter
thanks
Offline Jeff@TireBalls
  • 559
« Reply #3 on: August 29, 2007, 04:43:13 PM »
I've had the same thing happen and the hold it to the floor trick worked. Try that if the 24 hour thing doesn't help.
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Lisa
« Reply #4 on: August 29, 2007, 06:16:27 PM »
thanks
never thought that a simple battery change would cause such problems
do you know any other way to reset the computer?
  • 559
« Reply #5 on: August 29, 2007, 06:18:05 PM »
Thats the only way I know of. I do think that 24 hours is overkill. More like 12 should be more than enough.
Offline benzr2
  • 72
« Reply #6 on: August 29, 2007, 07:59:31 PM »
I know that on some vehicles that the radio fuse is the memory and removing it for 5 minutes with the battery unhooked will reset the computer.
Offline IanL
  • 466
« Reply #7 on: August 30, 2007, 03:56:35 PM »
To rest the computer, disconnect the battery and hold the brake pedal down for 30 seconds.  That's all it takes.
