Overheating Problem
  • 1562 Views
adamshumard
Overheating Problem
« on: August 29, 2007, 03:04:23 PM »
So the electric cooling fan on my 94 efi tracker quit. i replaced the fan and now it wont kick on. no matter how hot it gets. So i went ahead and hard wired the fan. Now with the fan running all the time the truck still overheats at an idle. When i take it down the highway though it does ok. coolant level is fine. But i cannot figure out why its overheating in town/at an idle. Its funny that so many issues would come up with the cooling all at once. Anyone have any idea what may be the cause?
Offline jeff1997
  • 1228
  • 27
Re: Overheating Problem
« Reply #1 on: August 29, 2007, 03:05:30 PM »
Water pump
3" Masterkit1 body lift
Custom strut spacers
adamshumard
« Reply #2 on: August 29, 2007, 03:11:21 PM »
If it was the water pump why would it cool goin down the highway? and by cool, i mean it runs at normal operating temp, not even a little high.
« Reply #3 on: August 29, 2007, 03:50:57 PM »
 A number of things can cause overheating, plugged radiator or coolant lines, weak water pump, non funtioning water pump, ( look for coolant coming out of the weep hole on the upper side of the pump) incorrect timing ( too far off advanced or retarded especially, can cause overheating.) You mentioned having an electric fan, that's not a stock item. I'm believe Trackicks came with a clutch operated fan, driven off the water pump pully. Check the simple things first, belt tension to the water pump being one.  A non-functioning fan will cause overheating in slow going, but at highway speeds there's enough air moving through the radiator to not need a fan. I replaced my clutch fan with a switchable electric fan so I could turn it off during deep water crossings. I don't even use it ( the fan) on the highway, and it's off most of the time in town as well.  Start by checking your timing. Specs are located on a tag under the hood, or in the FSM.
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« Reply #4 on: August 29, 2007, 04:40:20 PM »
Is it truly overheating or is the gauge telling you it's overheating? You might have a bad thermal sensor that reads the coolant temp and relays it to your temperature gauge. It's a possibility anyways.
-Adam
adamshumard
« Reply #5 on: August 29, 2007, 05:36:36 PM »
Goal!!! So i got it fixed. had to tighten the belt on the water pump. turns out it was slippin. thanks guys.
adam
« Reply #6 on: August 30, 2007, 04:10:12 AM »
Yeah, it's usually the simple stuff.
adam
Offline jeff1997
  • 1228
  • 27
« Reply #7 on: August 30, 2007, 01:44:05 PM »
adam
Glad you got it fixed. I replaced EVERYTHING on the cooling system, including the head gasket, earlier this year. Turned out to be a bad waterpump. The worst part was the new one I bought and installed first was bad too, thus I just kept replacing stuff!!
