going GREEN samurai!
  • 11 Replies
  • 2772 Views
Offline lokomonkey
  • 41
« on: August 09, 2007, 04:47:32 PM »
I used to owned a 91 SIDEKICK, but "had" to sell it, and deeply regret it.......now I want to get a SAMURAI, and fix it to the max! but, the deal is that I want to go GREEN, so I think, if I can fit a DIESEL engine in it, and tranform it to BIO-DIESEL, that would make me (and willy nelson ) happy, but seriously; is there a diesel engine that would fit this rig? which one?
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: going GREEN samurai!
« Reply #1 on: August 09, 2007, 07:04:26 PM »
As long as you don't go blue it's cool!!!!!
 ;D
Tracker-Kid
« Reply #2 on: August 09, 2007, 09:00:57 PM »
i don know if it would work but you should look into that jeep librety motor they come with a desel. or a vw bug
Offline whateverworks
  • 110
« Reply #3 on: August 09, 2007, 10:00:57 PM »
I have a better IDEA!!!!   DO A SEARCH!!!
TDI VW engines are the shizna for swapping a diesel into a Sammi.
Kelly
« Reply #4 on: August 10, 2007, 04:46:19 AM »
I don't kbow if you get them in the US but the 1.9TD Renault/Citroen engine is the one fitted to European built Sammis
Offline Amilla
  • 1076
« Reply #5 on: August 11, 2007, 10:52:28 AM »
http://www.rocky-road.com/diesel.html
Probably not the best site to order from but it will give you enough information to get an idea of what has to be done.
Its a bit pricey to do this, and i think the engines are pretty hard to get a hold of.
Also i have heard that the diesel swap will throw off all of your gear ranges.
Amilla
Offline brace
  • 264
  • I built it; I break it; I fix it.
« Reply #6 on: August 12, 2007, 05:05:00 AM »
Every once in a while you will see a diesel built Sammy on EBay.  I could have put my hands on an engine for this when I was in the States but I had to leave for Korea.  There are a lot of posts for this on this BBS and on the net for it too.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline v-stone
  • 625
« Reply #7 on: August 12, 2007, 04:14:43 PM »
bio-desiel samurai is one of my dreams that I will accomplish. Cool that you want to do it. VW radit desiels aren't to hard to find and I heard that with the RRO swap kit it will take you a day if your mechanical (of coarse that was a desiel mechanic experienced in this swap that said that). Good luck.
SAS Tracker! No looking back now.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #8 on: August 12, 2007, 07:43:00 PM »
While the forum "search" idea is a fine one, try doing a search for diesel at http://www.acksfaq.com/.  There you will find links to several excellent diesel Samurai forums and at least one vendor.
Also, if you check ebay regularly with a search for VW diesel (or similar) you find 1.6 and 1.9 NA and turbo-ed engines that can be used in a Samurai.
Hope that this helps!
Ack
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #9 on: August 12, 2007, 11:27:11 PM »
http://www.acmeadapters.com/index.php
and google can be your best friend. :)
Also hit up acks site it's well worth the time.
Mean Green Wheeling Machine
Offline SnoFalls
  • 1358
« Reply #10 on: August 13, 2007, 07:00:55 AM »
I wouldn't want to be behind your rig on the trail ...
Having hunger pains for frech fries all day would just suck  ;D
kingzoo
« Reply #11 on: August 16, 2007, 06:39:03 AM »
   Yeah.I want to import a euro diesel for my 1991 sidekick,and all other necessary stuff to do the swap.And if my dividend check is enough and a new motor and such isn't crazy,I just might.
  I love french fries!
