this thread is on every forum out there but some have a little more info added, like this....
Hey all I found this and though some one might like this:
Using Mercades arms
These are Mercedes Benz steering arms used to make a high steer setup on any 86-95 Suzuki Samurai. Use either one or both arms to move your drag link and tie rod up and out of the way of the rocks & remove bumpsteer.
!Modifications Required!
Drill out the center mounting holes to 9/16" or use a rat-tail style file to elongate the hole , purchase 2 of each of these bolts m12x1.25x50mm, m12x1.25x60mm, and modify your existing tie rod
!ISSUES!
drop pitman arm, liftblocks, axle turned so pionion points up, wornout (sagging) leaf springs can cause clearance issues. I have successfully installed in stock SPOA smaurai and in yj leaf sprung samurai
Stock setup with bent steering link (lots of bumpsteer)
Half OTT steering setup(removes bumpsteer, uses 1 arm no clearance issues)
Full OTT steering (Best setup, uses both arms read warning above)
