80 series landcruiser axles on my sammy? NEED INPUT!!!
  • 5298 Views
J-Ron
« on: July 19, 2007, 03:32:14 PM »
my friend recently rolled his 80 series landcruiser when we were just dickin' around out at boca reservoir
his axles are possibly available to me for dirt cheap, they have the stock lockers in them.
is there any way to put them underneath my sammy?
my main worry is that my stock, tired engine will barely turn the wheels.
i just need to make this work... any advice would make my day
Offline chet
  • 556
  • Zuki time!
Re: 80 series landcruiser axles on my sammy? NEED INPUT!!!
« Reply #1 on: July 19, 2007, 03:44:17 PM »
they will be quite a bit wider than stock. you will need to cut off all the link suspension crap and weld on leaf spring perches. You will also need to work on the electrical to get the lockers to work. I think they will be pretty close to stock samurai ratio (3.73:1) so tcase gears would be your best bet.
J-Ron
« Reply #2 on: July 19, 2007, 05:49:45 PM »
yeah, thats what i thought. it'd be way too much work to try and keep the coils. so a simple spring-over should do the trick? and if im way too underpowered, i can just find a lower geared t-case?
Offline RHodge
  • 523
« Reply #3 on: July 19, 2007, 11:08:07 PM »
I have a freind that just did that 80 swap, the steering was the bigest problem, with the tie rods on the rear and no one makes crossover steering for that axel I'll see if i can get some pics
later
ps you will have to make custom spring pads for the axel because the spring will be right |removethispart|@ the pumkin
« Reply #4 on: July 19, 2007, 11:53:05 PM »
I think those are the same ones Heather put on Her four door. full floaters, four wheel disk, high pinion front,e lockers 8).
Offline RHodge
  • 523
« Reply #5 on: July 20, 2007, 12:28:29 PM »
  not all were e-locked and full floaters, if thats what you want I'd double check them. I don't know what lockers you can get other then ARB if there not e-locked
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #6 on: July 20, 2007, 05:51:38 PM »
If they are the stock lockers then they are electric, and are likely full floaters.  You can get Lockrites for the axles if needed.  Check out IH8MUD.com for all kinds of info on the axles and upgrades.  It should be a good swap other than the steering as previously mentioned.   ;D
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
Offline Natebert
  • 1098
« Reply #7 on: July 21, 2007, 05:36:42 AM »
High steer problem is pretty easy to resolve.
Get high steering arm (for the drag link anyway) from OTT in BC.
http://www.granitepath.com/~kd7hcg/sidekick/pictures/toyaxles/toyaxles3/slides/DCP_6793.html
http://www.granitepath.com/~kd7hcg/sidekick/pictures/toyaxles/toyaxles3/slides/DCP_6794.html
Elockers are easy to retrofit without anything special.
(soldering skills needed)
http://www.granitepath.com/~kd7hcg/sidekick/pictures/toyaxles/toyaxles6/slides/DCP_6918.html
http://www.granitepath.com/~kd7hcg/sidekick/pictures/toyaxles/toyaxles6/slides/DCP_6927.html
Gear ratios (even on 35s) can be addressed with t-case gears (if necessary) even then I believe that most Toy axles come with 4.11 gears.
Good luck.
~Nate
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #8 on: July 22, 2007, 01:09:31 PM »
Inchworm even has an aftermarket electric locker control kit, if you need it.
http://www.inchwormgear.com/store/product_info.php?cPath=25&products_id=36
Heather Galvin
