Anybody using VTTR diff and/or panhard brackets?
  • 10 Replies
  • 2188 Views
Offline bzzr2
  • 1011
« on: July 06, 2007, 11:34:05 AM »
Just like the title says!  http://www.vttr.com.tw/e4X4.htm  i'm afraid my front end is gonna keep suffering if i don't do this and the warn hubs.  hubs 1st cause they're local parts...
« Last Edit: July 06, 2007, 11:35:55 AM by bzzr2 »
09 taco reg cab short box 4x4
Offline toofaroffroad
  • 226
Re: Anybody using VTTR diff and/or panhard brackets?
« Reply #1 on: July 08, 2007, 12:22:53 AM »
I own the VTTR Diff drop brackets and pan hard drop bracket. The front diff drop brackets are great...no problems. The rear ended up cracking on me after about 6 months.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: July 09, 2007, 04:15:49 PM »
Did the rear break from too much abuse or poor quality?
Offline bzzr2
  • 1011
« Reply #3 on: July 10, 2007, 08:52:05 AM »
i'm curious about that also, when it cracked did it let go or did you find a crack in it while cleaning up or something like that?
  • 226
« Reply #4 on: July 11, 2007, 08:13:39 PM »
Truthfully i'm not sure. I've taken it off road about 4 times on pretty big rocks...for a 99 tracker. I didn't even notice and one day i took my truck into my mechanics to have the brakes done and he told me the pan hard bracket was cracked.
Offline bzzr2
  • 1011
« Reply #5 on: July 12, 2007, 08:41:26 AM »
ok, good to know that it didn't let go and F up your rig!  did you weld it to fix it or just remove it?   how much rear lift are you running?
Offline bzzr2
  • 1011
« Reply #6 on: July 13, 2007, 07:12:42 AM »
i got in contact with vttr, quoted 180usd shipped to canada for all parts.  the front drop brackets are 80usd & the panhard bracket is 32usd.  is anybody else interested in any of these parts?  the shipping is 68usd, i don't imagine it would change if anybody else wanted to piggyback the order.  i'll wait to hear if anybody is interested but imagine i'll order soon.  cheers - B
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #7 on: July 13, 2007, 09:34:11 AM »
I'd be interested in the rear bracket if I could find somewhere that sells the strut extensions, I'm having no luck finding those
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline bzzr2
  • 1011
« Reply #8 on: July 13, 2007, 10:49:47 AM »
what about going directly to bds for a distributor?  they should be able to point you in the right direction.  let me know if you have any luck.
Offline biker
  • 730
« Reply #9 on: July 17, 2007, 06:37:00 PM »
The local supplier can't or won't come up with anything and I don't see a direct link to contact BDS on their site  ??? I see Boondox has them on their site but they seem to be in limbo, any other ideas
99 Vitara 2wd
10 Gr Vitara
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: July 17, 2007, 06:39:30 PM »
Tried a semi-local supplier?
I had mine shipped to me from an hour away as the local supplier wasn't helpful either.
