Trans problem on my 02 GV!?
  • 1144 Views
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« on: June 17, 2007, 06:51:15 PM »
My trans work realy well but when I want to down shift from 5 to 4 the stick get stuck in neutral? And I need to fight a litle with to unstuck it...
This problem happen only 25% of the time.
What do you think?
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline IanL
  • 466
Re: Trans problem on my 02 GV!?
« Reply #1 on: June 18, 2007, 12:45:49 AM »
Maybe the clutch is not fully releasing?
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #2 on: June 18, 2007, 08:22:26 AM »
MY 99 GV used to do this when it was still pretty new.  After driving in 5th gear for a while on the highway, I would try to go to 4th and it would stick.  The dealership replaced the "shifter housing case" at around 16,000 miles and that seemed to help.  Good luck.
Dave
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Offline Fredo
  • 416
« Reply #3 on: June 18, 2007, 03:08:16 PM »
shifter housing case???
And how much this cost?
Offline Davyboy
  • 252
« Reply #4 on: June 18, 2007, 10:07:29 PM »
It was under warranty.....so it was free.  I don't know what it will cost you.  Sorry.
Dave
