Lets see your ride!!!
  • 352 Replies
  • 100085 Views
0 Members and 18 Guests are viewing this topic.
Offline Jeff@TireBalls
  • 559
Re: Lets see your ride!!!
« Reply #60 on: December 06, 2007, 10:46:29 AM »
How did you get the PC off of the lip?
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Offline zukipro
  • LOOK TWICE...A SUZUKI BEAT YOU!
« Reply #61 on: December 06, 2007, 03:41:02 PM »
What piece are you talking about?
  • 559
« Reply #62 on: December 06, 2007, 03:42:52 PM »
PC = powder coat
Offline zukipro
« Reply #63 on: December 11, 2007, 09:13:15 PM »
I had to use this yellow tape that wont melt and apply it the the lip before the powdercoat. It was a pain because the glue stuck to the lip and i had to use acetone to remove the glue. The wheels originally were all aluminum until i had the centers powder coated.
  • 559
« Reply #64 on: December 12, 2007, 05:31:32 AM »
Nice! I'd like to do that to my stockers. The clear coat on them is peeling away.  >:(
Offline zukipro
« Reply #65 on: December 12, 2007, 09:16:02 PM »
I took my original steel silver wheels and wire brushed them down to the metasl and had them powder coated black also. This way when its parked it still looks nice. What new mods have you done on your car?
  • 559
« Reply #66 on: December 13, 2007, 05:43:55 AM »
In the last 6 months installed a snorkle, roofrack, 5.12 gears, manual lockouts and I have a set of rock rails that I still need to install.
oilstained
« Reply #67 on: December 18, 2007, 08:02:54 AM »
well i just got on here so, my turn in my ride. its a ZR2 2001, 2dr with cut off muffler calmini 2.5 lift with a set of jeep coils in the rear, and 4.24 calmini gears in the t-case, superwinch hubs on 31x10.50 pro comps that are gonna turn into 265/75 toyo at
  • 559
« Reply #68 on: December 18, 2007, 08:09:01 AM »
Which Jeep coils did you use? XJ, TJ..front,rear? How much lift did it give you and was there any mods required?
oilstained
« Reply #69 on: December 21, 2007, 02:22:54 PM »
the coils i used are those of a stock xj, it sits almost an inch taller than the coils that came with the calmini lift, for install they are a bigger coil than stock, so i swapped sides, so they sit on the mounts firmly, its a heavier spring rate, so it can be loaded more without the drag of the stock spring rate, they still flex out great.
  • 559
« Reply #70 on: December 21, 2007, 02:28:42 PM »
So how much lift do you think you gained?
oilstained
« Reply #71 on: December 21, 2007, 03:00:05 PM »
the lift gained is roughly bout 3.25 over the stock spring, and almost an inch over calmini lift spring.
here is some specs on springs, and the set of xj's i have i got off ebay for like 20 bucks.
XJ coil measures: 17" tall, 5" dia. and uses 0.475" dia. wire
TJ coil measures: 18.5" tall, 5.25" dia. and uses 0.575" dia. wire
95 Aerostar coil measures:13.625" tall, 6.5" dia. and uses 0.600" dia. wire
2dr Kick rear measures: 12.5" tall, 4.25" dia. and uses 0.460" dia. wire
2dr Kick front measures: 10.875" tall, 4.375" dia. and uses 0.600" dia. wire
  • 559
« Reply #72 on: December 21, 2007, 03:09:06 PM »
Thanks oilstained, thats great info!
oilstained
« Reply #73 on: December 23, 2007, 09:12:21 AM »
no prob all that i found on another forum, i have forgotten now, but when i found that i saved it all for future projects.
« Reply #74 on: December 25, 2007, 12:19:39 AM »
I dont think I´ve posted in this thread.
Heres my GV 2001 V6 manual. Its got a 2 inch body lift, custom fender flares, 35x12.5x15 tires, 15x10 alloy wheels, 4.88 diffs, cb radio and antenna and a sound setup. I panted the wheels, middle of the grill and inside the headlights this summer.
