Lets see your ride!!!
  • 352 Replies
  • 99479 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Lets see your ride!!!
« Reply #300 on: August 23, 2012, 11:26:10 AM »
Sadly not available in North America.
Offline built4thrashing
  • 9
  • Built by me. Built4thrashing
    • Cross Country Jeep Club,
« Reply #301 on: August 27, 2012, 04:25:25 AM »
Quite happy with the rear flex now.
Driven like its a rental.
Offline Toy Box
  • 222
  • 00 Grand Vitara
« Reply #302 on: August 27, 2012, 07:37:27 AM »
Were did you put your dual battery can you give me a picture. Great looking ride
You Play you Pay
  • 9
« Reply #303 on: August 28, 2012, 01:45:38 AM »
Being an early model it had the washer under the bonet next to the radiator. I relocated it to inside the guard using a later models washer. Also had to move the rad overflow bottle to oposite side.
From there i made my own tray and fitted a D34 optima yellow top. Isolation is controled by an automatic redarc 100amp isolator. Since photo was taken i have replaced the Delcor battery with a N70ZZL (700CCA) and installed a battery monitor to keep an eye on the state of charge in the 2 batteries.
Offline bush buster
  • 263
« Reply #304 on: August 28, 2012, 10:30:04 AM »
hay bush buster what are the rims on the white vitara off of? and are they 15 or 16?
Oops, it's been a while since i've been on here. The rims cam off a ford truck but the guy told me they originally came off a barracuda. They required wheel spacers to fit as well as lower profile bolt heads on the hub bolts.
(FOR SALE, drop me a line) '01 Vitara 2.0, 2" suspension lift, 2" body lift, 31x10.5x15 Interco TRXUS MT's on ford truck turbine rims, 1" wheel spacers, manual hubs, 5125 gears (Sidekick rear and GV steel front). DD/bushmobile "Snowflake"
'06 Impreza - Wife's ride and road tripper
1975 Dodge 360 Sportsman 1 ton van chassis with a 21' Triple E Class C motorhome
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #305 on: August 28, 2012, 01:03:01 PM »
I think he was mistaken.  Plymouth Barracuda's used a 5x4" bolt pattern.  Much smaller than our 5x5.5" pattern.
However Barracuda's did have a similar wheel to your "Turbine" style rim.  He may have meant that or been confused by it.
Offline diftoyota
  • 253
« Reply #306 on: August 28, 2012, 01:11:05 PM »
hum my friend bought a set in moncton new-brunswick canada, told me they were remolds
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #307 on: August 28, 2012, 01:33:53 PM »
Last I knew Silverstone (and the Simex tires they are modeled after) aren't available in the US/Canadian market.  Supposedly you can get them imported through some online tire dealers overseas but no clue on the veracity of that.
The Simex and Silverstone tires are brand new tires.  If someone in NA makes a recap with a similar tread than that's something else.
Offline bush buster
  • 263
« Reply #308 on: August 30, 2012, 06:13:59 AM »
Interesting, either the old guy was full of it (don't know why he would make that up) or his memory is failing after all these years! He was scrapping the old F150 so it had probably been a while. Oh yeah, they're 15".
Offline zuki709
  • 190
  • 6
« Reply #309 on: August 31, 2012, 08:09:22 PM »
they are awesome 8) love the look of them.
91 Samurai in many pieces
01 Tracker MUD CHILD's 2" suspension lift & 2" body lift. air lift air bag 1000 in front. 31x10.50X15 on stock samurai wheels.
  • 9
« Reply #310 on: September 08, 2012, 06:57:00 PM »
Im running 31x10.5 16 Silverstone Xtremes and what i had to do so the wouldnt rub inside the front guards was remove the inner plastic guard and flatten the panel lit a bit.
There is nothing you can really do about them rubbiung on the chasis as the GV's dont have steering stops.
Really close. Actually rubs when turning in reverse.
Marked where it needs more clearance.
Lots of mud behind plastic panel
Fold flap straight then hammer flat.
All flattened and sprayed black
Heaps more space.
Gained about 10-15mm and took about 1/2 hour to do.
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
« Reply #311 on: September 24, 2012, 06:53:30 PM »
Grand Vitara |removethispart|@ Trailblazers King of the Hill
Offline Toy Box
  • 222
  • 00 Grand Vitara
« Reply #312 on: September 24, 2012, 08:02:56 PM »
Great job !
You Play you Pay
« Reply #313 on: September 25, 2012, 08:22:40 PM »
Hi there!!!
New in the community, always be quad-rider so this time change a little bit ---almost same size with a lot of better things to do with!!! --- so here's my ride:
-- 2001 Chevy Tracker 2d a a/c 4x4 101k bought it a month ago.
-- K&N oem fit air filter
-- 2in suspension lift (installed by myself)
-- 30x9.50 R15 on oem wheels (love them)
next to do:
-- 2in body lift
-- electric radiator fan
-- rockford fosgate oem size speakers
-- double din alpine head unit
-- bull bar with winch.
Offline max-zr2
  • 45
« Reply #314 on: October 16, 2012, 01:01:28 PM »
Finally got the tires and rims mounted on the ZR2.   Running Jeffs Coil and strut spacers, as well as Doetsch tech shocks. 30X9.5" General Grabber AT2's on 15x7" rims (had to grind the calipers slightly.   Have the BL sitting in the shed, but the weather and homework haven't allowed me to install it yet.    Im going to reinstall the rear bumper after the BL, and leave the front off until I can find something better.  Haven't had much rubbing yet.   but I know I will need to do some trimming and banging.   Work in progress...
Installed:
- Jeff's 2" coil spacers,  Doestech shocks (21.5-13.5),  free wheelin' hubs, 15"X8" American Racing rims (4"backspacing), 30X9.5 General Grabber AT2's, K&N Filter, Snorkel,  XL-7 Rear springs
Installing:
- 2" BL
