0 Members and 28 Guests are viewing this topic.
03 vitara sas, 33pro comp extreme mud, 5.13's, locked in rear, custom built long arms, 3 link in back, 4 link in front, with power steering box from 97 sport sidekick, First trip out, one long winter build works fickin awesome
I know this thread is alittle old, but I thought I'd post my 2000 Tracker.
Barely any! If you run those same wheels you have in the picture, your only rub will be when you turn super tight, it will rub on the frame behind the front wheel, and on the A-arm in front of the front wheel. The rear wheel will rub on the plastic inner fender liner, but it's fairly minor. If you get wheels that stick out more you will need to trim alot!
Quote from: olija on June 22, 2009, 09:28:13 PMBarely any! If you run those same wheels you have in the picture, your only rub will be when you turn super tight, it will rub on the frame behind the front wheel, and on the A-arm in front of the front wheel. The rear wheel will rub on the plastic inner fender liner, but it's fairly minor. If you get wheels that stick out more you will need to trim alot!Is it really ok to run 31x10.50 tires on the stock (6 inch?) rims? I have a set of 8" wide cj wagon wheels i was gunna use.
