Broken Lugs
  • 1643 Views
Offline Yoak
  • 577
Broken Lugs
« on: June 04, 2007, 07:42:22 PM »
Hey Gang,
I managed to break several lugs on my front passenger side this last week...
Seems as if one lug was loose and allowed the rim to rotate...and thus weaken the other lugs around them....when I tried to tighten one the was visibly loose it broke of....I have since removed the tire from car and after inspection they will all need to be replaced....
Any Advice here, should I replace them with replacement bolts or should I just replace everything?
Re: Broken Lugs
« Reply #1 on: June 04, 2007, 08:12:45 PM »
At least change the five lugs and lug nuts.
g-man
Re: Broken Lugs
« Reply #2 on: June 04, 2007, 08:17:52 PM »
Just change all five lugs and studs, they are cheap.
Offline museboy07
  • 641
Re: Broken Lugs
« Reply #3 on: June 04, 2007, 08:20:16 PM »
ya change 'em all.  Its easy on these trackicks.  The studs are on the drums and rotars
Offline Yoak
  • 577
Re: Broken Lugs
« Reply #4 on: June 05, 2007, 12:30:10 AM »
So I take it that this is a local auto parts item?
Re: Broken Lugs
« Reply #5 on: June 05, 2007, 03:48:54 AM »
Most major chains have them, but they are an ODD size: 12x1.25mm. I've had to replace a few when I first got my Tracker. I always use nickle anti seize on them now. No problems.
