custome front bumper
  • 14 Replies
  • 2399 Views
Offline toofaroffroad
  • 226
« on: May 22, 2007, 10:23:37 PM »
Hi, here is a shot of my 1999 Tracker. I had the front bumper custome built.
It's your standard 2" body lift with 1.75" coil spacers. OME fronts with Rancho 5000 in rear. The tires are 31/10.5/15 Pro comp muds on 7" rims. truck is running great.
Next up is sidekick gears, rear locker and rock rails.Then I'm done...maybe.
Offline biker
  • 730
  • It's a sickness I tell ya
Re: custome front bumper
« Reply #1 on: May 23, 2007, 07:16:57 AM »
Truck looks great, I just picked up an 01 but it will stay more tame I think  ::)
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
  • 226
« Reply #2 on: May 23, 2007, 11:49:34 AM »
Funny thing, thats what I said when I picked mine up.
« Reply #3 on: May 23, 2007, 09:53:45 PM »
Don't they all start that way?
 ;) ;D
Offline biker
  • 730
« Reply #4 on: May 23, 2007, 10:33:05 PM »
I have this to play with so I should be able to keep the new one nice ;D
99 Vitara 2wd
10 Gr Vitara
Offline benzr2
  • 72
« Reply #5 on: May 25, 2007, 08:29:16 PM »
I like it , it looks great. I will be doing the same in lift and I like the way it looks. Who made the bumper, I m looking for one
2001 Tracker ZR2 235/75/15 ATs       1987 Samurai Tin Top     New Project!!
  • 226
« Reply #6 on: May 28, 2007, 11:31:53 PM »
The bumper was made by a buddy. I wasn't able to find anything online pre made that was decent.
Offline r3cc0s
  • 321
« Reply #7 on: May 29, 2007, 07:22:06 AM »
Out of curiosity...
I'm running 245/75/16's with pretty much the same lift as you, but on the stocker rims
You running 31 x 10.5's... how bad do you get rub on full lock? Or did you somehow manage to add some width to your front end?
I'm contemplaiting getting some cookie cutter tires 235/85/16's but getting a set of 1" or 1.5" wheel spacers for the front
Offline bzzr2
  • 1011
« Reply #8 on: May 31, 2007, 07:09:27 AM »
get the cookie cutters!  mine work great!  i don't think you'd need to go wider then 1inch if you are only planning on putting the spacers on the front.  i've never actually checked how much width i lost when lifting but i wouldn't think more than 2inches.  my 31x9.5 tsl's rub hard at full lock, i'm glad the tires aren't any wider!  btw - i have no spacers, any larger diameter tire and i would probably buy some because the turning radius would be getting bad.
« Last Edit: May 31, 2007, 07:43:00 AM by bzzr2 »
09 taco reg cab short box 4x4
  • 226
« Reply #9 on: May 31, 2007, 04:40:34 PM »
I'm running 31x10.5/15 on 7" rims. I belive the offset is 3.75. I also put the quarter inch wheel spacers on. At full lock I get minor rubbing but it doesn't affect the drive. apart from that they are great. With my wheels I had to instal the wheel spacer in order for the brake calipers ot work properly.
They are the black rock crawler rims. 7x15 got them from www.4wheelparts.com
You should be able to find all the back spaceing and other info on thier website.
Offline biker
  • 730
« Reply #10 on: May 31, 2007, 05:50:38 PM »
Where did you get the 1/4" spacers and how much are they? I need a set to mount up the mags I want to put on my 01 to clear the calipers.
Thanks
99 Vitara 2wd
10 Gr Vitara
Offline bzzr2
  • 1011
« Reply #11 on: June 01, 2007, 07:18:32 AM »
i recall somebody mentioning those 1/4 spacers being available on ebay in the past.
  • 226
« Reply #12 on: June 03, 2007, 04:59:14 PM »
Yes I got them on ebay. $20 for two.
Offline lowrezolution
  • 292
  • "Get bent!"
« Reply #13 on: June 03, 2007, 05:25:24 PM »
Any chance of a larger pic.
I am trying to come up with a design for my bumper and that looks sweet. ;D
Thanks
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline r3cc0s
  • 321
« Reply #14 on: June 03, 2007, 10:34:05 PM »
order the 2" RRO BL
Instead of getting new rims, of which the most backspacing I can find in Canada as being 3.75"
I'll order 1" wheel spacers for the front so it will give me back the width that I lost from the almost 2" front suspension lift with the stock A arms
I'll keep the 16" Rims from the Vitara I'm using and get the tall skinnies 235/75/16s on BFG all terrain
UNLESS someone can find me a good set of AT's in that size which aren't a freaking E ply
I'd be happy with C
