Hagen widening trick on GV ?
  • 1670 Views
Offline ngrover
  • 131
« on: May 04, 2007, 02:08:38 PM »
Has anyone done the Hagen widening trick on our gen Vitara? Sounds like what I'm looking for.. it moves the front wheels out and forward by an inch. This might give me the clearance I need for some bigger rubber.
Link: http://www.zukiworld.com/month_120102/feature_hagan_frontendmod.htm
2000 Suzuki Grand Vitara, 5spd. 2.5 inch lift, 225/75R16 AT's
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Hagen widening trick on GV ?
« Reply #1 on: May 26, 2007, 10:04:52 PM »
I did this mod on my 91 and it works well but while under my 01 I was looking at the susp and found that the crossmember that the rear of the control arm bolts to is shaped wrong to allow this mod to be done
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline sergi
  • 307
« Reply #2 on: June 06, 2007, 07:23:07 AM »
I had a look too but it seems the metal is curved into a lip so you can't really move it out quite a lot. I would really like new control arms ::).
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
