The head is a direct swap, but the distributor
drive is head specific, you need to use the 1.3
drive housing on the 1.3 head, but the distributor
might not fit the 1.3 housing, I had to remove the
tip of a 1.3 distributor to fit into a 1.6 head, if I
remember right, the 1.6 dizzy fits the 1.3 OK
but I'm not sure, and you need to block the fuel
pump opening if you aren't using it
