Ironman suspension?
  • 1617 Views
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
Ironman suspension?
« on: April 29, 2007, 06:11:55 PM »
What is the différence between http://www.ironmansuspension.com/ and Old man emu?
Did somebody test ironman suspension product?
thanx!
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline Ben
  • 16
  • Grand Vitara's rule!!!
Re: Ironman suspension?
« Reply #1 on: April 29, 2007, 06:16:55 PM »
OME is the ducks guts suspension wise for Suzi's. I looked into ironman but all of the forums said they were too stiff/harsh as they are predominately designed for heavier 4wds - toyotas/nissans etc. Makes sense.
I have OME on my GV and haven't looked back.
2002 SWB Grand Vitara, OME suspension lift, huge 225/75R16s, electric windows and sheepskins ;-p
Offline toofaroffroad
  • 226
« Reply #2 on: May 01, 2007, 11:17:09 PM »
I spoke with someone at "Iron Man" in Australia. They informed that the 2" coils for Vitara actually lifted you up 1.5" and that the ride was stiffer then stock.
Offline Ben
  • 16
« Reply #3 on: May 02, 2007, 05:19:18 AM »
Yeah, OME is about the same amount. I think 35mm is as high as they will go as ARB classify it as an "improvement", not a "modification", ie, it won't damage CVs etc. I guess you can either source taller springs or add spring spacers.
Offline ZeusZuki
  • 411
« Reply #4 on: May 03, 2007, 01:09:15 AM »
You want "the ducks guts" then you can not beat Calmini. I run their kits and NOTHING comes close as far as tweaking Vits / GV's go  >:D
ZeusZuki  8)
Offline thrash
  • 54
  • thrash thrash thrash
« Reply #5 on: May 12, 2007, 11:16:25 PM »
ZeusZuki  8)
I CONCUR
jeeps are like tampons
every pussy needs one
http://www.cardomain.com/ride/2295298
