Er, the fuse I told you about above is actually the condenser cooling fan. Just realised you said it doesn't blow air. That fuse is No 26, 30A BLOWER, in the box above the driver's leg. It's the lefthand of the center row.
It, also, is powered from main fuse No 5, 60A.
BUT, it only gets power to the motor if the heater relay is powered, which happens when the ignition is turned on and supplies power thru Fuse No 23 15A (Rear defogger - YES!). Now the heater relay is on the side of the blower motor over passenger's legs, and fuse No 23 is on the lower row above the driver's leg, seven from left, four from the right (I put it this way because my drawing shows two unused positions, but they may not be unused in your truck).
Now, it looks like fuses 5, 23 and 26 all have to be ok, as well as the heater relay, for the blower to work. Good, isn't it?
