Vortec V6
  • 2237 Views
Offline explosivo
  • 3157
Vortec V6
« on: December 18, 2004, 10:09:48 PM »
As much as I don't like the idea of this swap due to weight, I can get a vortec for free. All I'll need after that is a tranny.
The question I have is are there aftermarket intakes to put a carb on it rather than using the EFI?
omghi2.us[/url]
95xl7
Re: Vortec V6
« Reply #1 on: December 19, 2004, 02:00:54 AM »
Why would you want a carb?
Offline bandit86
  • 1641
  • elv8rguy
Re: Vortec V6
« Reply #2 on: December 19, 2004, 02:05:30 AM »
newer marine singleplanes should work. vortec intake manifold bolt holes are at a different angle then regular intakes, or so I've been told. I'd keep it efi, makes a world of a difference.
Offline techie
  • 80
  • On the mountain anytime
Re: Vortec V6
« Reply #3 on: December 19, 2004, 03:29:16 AM »
Should be able to find an adapter to marry your tranny to the Vortec.
Re: Vortec V6
« Reply #4 on: December 19, 2004, 04:10:39 AM »
Also painless wiring makes a universal harness for that motor to go into ANY car. If I remember right its only like $250.00
Re: Vortec V6
« Reply #5 on: December 19, 2004, 04:14:27 AM »
$250 for wires, doesn't sound painless to me
Offline explosivo
  • 3157
Re: Vortec V6
« Reply #6 on: December 19, 2004, 05:54:56 AM »
My thoughts exactly.
And as for going carb'd, it's easier to tune and mod with my limited experience. Plus the engine doesn't come wiht a computer, so that means more junkyard shopping + more expense to the total project.
omghi2.us[/url]
Offline 92Sidekick4x4
  • 1456
Re: Vortec V6
« Reply #7 on: December 19, 2004, 06:06:06 AM »
if i were to do an engine swap i think id prefer a carb after what my computer has caused for me
Offline real_red_wagon
  • 226
  • Make It Hert!!!
Re: Vortec V6
« Reply #8 on: December 19, 2004, 07:50:30 AM »
   If your talking 4.3 there are a number of manifolds available check out sumitracing.com I just looked and edelbrock makes a couple different performer intakes for it 2 or 4 barrel different powerbands and such ;)
 this is the one for the vortec 4.3 the heads are a little different than the older ones
    these engines are carbon copies of the small block v8 you can actualy run one off a v8 distributor we did once in a pinch. there are countless trans combos that bolt to the 4.3 check into older k5 blazer and pick up  stuff, the front drive shaft comes out on the pass side. most small block v8 parts fit and work on the 4.3 good torque you'll have to watch your gearing these engines don't like to rev like a 1.6 ;D
At Lakeview Motorsports, were wasting your time already!
