Diff drop question..
  • 1253 Views
Offline museboy07
  • 641
« on: April 23, 2007, 06:53:22 PM »
How do you drop the front differential when the crossmember sits right below it?
BudweiserQuinn
Re: Diff drop question..
« Reply #1 on: April 23, 2007, 08:06:41 PM »
If you want, I can look it up on all data tomorrow moring and repost the step by steps.  This goes for anyone on anything...
Offline kirknd4spd
  • 333
« Reply #2 on: April 23, 2007, 08:56:09 PM »
longer brackets at the front of the diff, and a shorter bracket at the back. its really simple, and it does the job.
Offline BigPig
  • 276
« Reply #3 on: April 23, 2007, 10:42:14 PM »
I saw pics of the calmini drop brackets and they look like they drop and rotate it slightly at the same time.
'89 Sidekick w/ 4.5" of lift.
Offline museboy07
  • 641
« Reply #4 on: April 24, 2007, 04:01:59 AM »
well if it only lowers it to the the cross member then whats that...like an inch?
  • 6544
  • 64
« Reply #5 on: April 24, 2007, 11:08:35 AM »
« Reply #6 on: April 24, 2007, 12:22:13 PM »
The front Calmini brackets are about 2" longer, the rear drops by about 1/2". Its really more of a rotation but it brings the driveshafts down. When topping up the diff oil you need to lift the front or park on a good slope or you won't get enough oil in.
