87 samurai running funny need advice!
  • 1944 Views
87sammibob
« on: April 18, 2007, 02:55:27 PM »
hi hows it going! i have  a 87 suzuki samurai  that just started acting funnny! when its cold it starts to sputter at high rpm and sometimes when its hott? then all the time when i decelerate it does a loud back fire. my sammi has a custom exhaust system with a calmini header. any ideas on what to check and maybe how to fix it thanks for all your help! ??? ???
Offline W.O.T
  • 38
Re: 87 samurai running funny need advice!
« Reply #1 on: April 18, 2007, 07:50:16 PM »
sounds like its running lean.  your carb probably needs to be adjusted or cleaned.  id look there first.
87sammibob
« Reply #2 on: April 18, 2007, 09:40:50 PM »
how much work ad how hard is it to remove and clean the carb? will i need to buy any new gaskets if i remove it?
Offline Amilla
  • 1076
« Reply #3 on: April 19, 2007, 09:02:56 AM »
Hey 87sammibob,
Its not that hard to pull the carb off at all, the nuts that are on the vavle cover side are a little tricky to get off.  Because of the lack of space, but if you have a shorty 12 mm wrench, it makes a so much easyer.
I just pulled mine off the other day, i didnt need a new gasket.
Mine used to backfire pretty bad, put a new o2 on it and it stopped most of backfires, it will do it once in a while.
hope that helps
Amilla
« Reply #4 on: April 19, 2007, 10:25:49 AM »
Check this post out for carb rebuild:
http://bbs.zuwharrie.com/content/topic,21551.15/topicseen.html
And, check your timing. My vehicle was doing the similar thing, come to find out it was off by 10 degrees! It helped a lot to correct the timing.
« Reply #5 on: April 19, 2007, 10:45:46 AM »
Check your valve lash too you may have an exhaust valve thats tightened up.
