clutch pedal feel
  • 1111 Views
Offline KickTurn
  • 53
  • My wife likes the smell of petroleum products.
clutch pedal feel
« on: April 17, 2007, 10:25:01 AM »
I've adjusted the cable to spec.  The disengagement point is spot on, but the pedal has a goofy feel to it.  Increasing resistance at first, like you would expect, but after about 1.5" of travel, the resistance is really minimal.  So, even though the clutch is disengaging after about 1" of travel, the light resistance means that I often end up sending the clutch almost to the floor anyway.
Anyone have any clues?
Thanks.
95 Kick JLX 4x4 4dr 1.6 16v.
235s, manual hubs.
Offline BigPig
  • 276
Re: clutch pedal feel
« Reply #1 on: April 17, 2007, 05:30:06 PM »
Quit doing such heavy leg presses at the gym!  ;D
'89 Sidekick w/ 4.5" of lift.
Offline LawDog
  • 531
    • Emerling Chevrolet
« Reply #2 on: April 18, 2007, 07:14:12 AM »
Is it a new cable?  If not it could be streched out, worn out, or woven through the engine compartment the wrong way.  If it is new then the only other thing I can think of is the spline on the lever where it connects to the tranny.  If that spline is worn enough to allow the clutch to release when you get to a certain point, rendering your pedal and cable useless the rest of the way up or dow, it might cause it to feel like you are describing.   Otherwise, I've worked clutches on a number of Sammis and Trackers and not a one of them felt the same.  Some do feel rather "limp."  I would say if you are sure the clutch is always engaging/disengaging all the way then apply the "if it ain't broke, don't fix it rule" and leave it be.
Offline toolman21
  • 229
« Reply #3 on: April 18, 2007, 08:17:43 AM »
After my factory cable broke (got into the power steering pump), I put in an aftermarket one and it has never really felt right to me, but it works.
Toolman
Offline KickTurn
  • 53
« Reply #4 on: April 18, 2007, 09:01:12 AM »
It's not a new cable.  I don't know if the previous owner replaced it or not, but I'll check the routing.
235s, manual hubs.
