lengths of coils...?
museboy07
641
April 15, 2007, 09:08:58 PM »
What is the length of a 2 door tracker coil spring, 4 door spring, and GV spring?
tipover
422
4
Re: lengths of coils...?
April 15, 2007, 09:16:58 PM »
My 95 four door springs are:
fronts 10.75 inches
Rear 12.5 inches
thats all I know
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
AJMBLAZER
2166
Your mom.
April 16, 2007, 01:42:50 PM »
Length won't tell you much. You actually want to know the whole picture like lengths, wire diameter, and especially spring rate.
If I can recall correctly OME's XL7 spring is actually a hair shorter than it's GV spring.
bzzr2
1011
3
Reply #3 on:
April 17, 2007, 09:57:41 AM »
according to arb's ome info the gv spring is 30mm longer the the kick front coil, no idea about the rear.
09 taco reg cab short box 4x4
bentparts
4536
60
I'd rather be Blown AND Injected.
Reply #4 on:
April 17, 2007, 03:23:37 PM »
I know the OME "heavy" rated spring is a 540 lb spring rate, and new has a free length of 11".
