your opinion
your opinion
blakester1123
95
88 sammy 6in on 32s and rising
your opinion
April 13, 2007, 05:44:18 PM »
35 inch tires on stock samurai axles with the heavy duty shafts? whould it break or would i be fine if i had the gear to turn them?
Amilla
1076
Toyota running gear was made for a samurai!
Re: your opinion
April 13, 2007, 06:03:53 PM »
I think the double tuff and newfeild berfs. (correct me on the name if thats wrong)
are supposed to be able to hold up to that size tire.
Amilla
blakester1123
95
Re: your opinion
April 14, 2007, 03:17:36 PM »
checked them out on trail toughs site it says to use rear samurai side gears, does this mean you could run a rear spool in the front?
phloop
Re: your opinion
Reply #3 on:
April 14, 2007, 06:34:06 PM »
Sounds like you can run that rear spool up front.
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
Re: your opinion
Reply #4 on:
April 14, 2007, 06:41:42 PM »
yep
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
