Plugged up EGR system
  • 1161 Views
Offline Amilla
  • 1076
« on: April 13, 2007, 12:08:47 PM »
I took my 88 sammi into get smogged.  As i expected, it didnt even come close to passing smog.
The EGR valve doesnt work and the system is plugged up.
What should i do?  Im pretty sure im going to buy a new EGR valve.
is there anything else i should do?
Thanks
Amilla
Offline da_tub
  • 307
Re: Plugged up EGR system
« Reply #1 on: April 13, 2007, 12:16:23 PM »
check all the lines to , the ones comming from the egr also  check the pvc one's too they get all plugged up also i used carb cleaner to clean the lines out in mine ,, you may have to use some wire to punch through if there plugged right off.. good luck hope that helps
91 four door ,and some stuff
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #2 on: April 13, 2007, 12:26:01 PM »
remove the Egr also, and see if the port is clogged up....
Offline BigPig
  • 276
« Reply #3 on: April 13, 2007, 02:28:43 PM »
What should i do?
Move to Oregon!  Outside the Portland and Medford areas we don't have smog checks.  ;D
'89 Sidekick w/ 4.5" of lift.
Offline Amilla
  • 1076
« Reply #4 on: April 13, 2007, 06:08:42 PM »
Thanks for the information, im probbly going to start working on it today or tommrow.  Try and get all those bugs worked out and it all smogged.
I know oregon is where its at, CA is the worst for emissions.
Thanks
Amilla
