Will someone please tell me how to do this...
  • 1626 Views
Offline museboy07
  • 641
« on: April 12, 2007, 11:26:59 AM »
How do you modify the lower strut hole to fix camber issues on a lifted tracker?
Offline Uncivilized
  • 1469
    • Car Domain
Re: Will someone please tell me how to do this...
« Reply #1 on: April 12, 2007, 12:31:12 PM »
The strut bolts to the knuckle with 2 bolts. The top bolt is the on you modify. Here's how I did mine for a 2.25" total front lift:
I removed the top bolt, then pushed the spindle in towards the strut until it stopped.
I used a die-grinder with a good cutting bit, and ovalized the hole till the bolt went back in and through the knuckle.
Done!
I have a thread here somewhere with a few pictures, I'll find it and update later.
Offline BigPig
  • 276
« Reply #2 on: April 13, 2007, 12:15:50 AM »
I just bought adjustable camber bolts and they worked awesome.  I searched around the net and found them for only $16 for the set.  Priority shipping w/insurance was $9.90, so for $25.90 I got it done quick and easy.  Here's a link for the place I bought them.  They are sold by a ton of companies as adjustable camber bolts #81250 and the same bolts fit a bunch of applications since you are just going by the bolt diameter.  For a Track/Kick it is a 12mm bolt.
http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=81250
'89 Sidekick w/ 4.5" of lift.
Offline tonyman246
  • 58
« Reply #3 on: April 13, 2007, 09:20:32 AM »
just go to your local auto parts store. they sell for 20.00 for the set.  much easier than messing with a grinder or the internet. (in my opinion)
1991 Geo Tracker 33" super swampers + 4" lift + minor fender trimming + locker = unstoppable!
Offline BigPig
  • 276
« Reply #4 on: April 13, 2007, 02:46:19 PM »
That works too.  I couldn't find them locally though.
Tonyman you have any pics of your rig?
