Will 30x9.5-15 fit on my stock track wheels?
  • 10 Replies
  • 2974 Views
Offline museboy07
  • 641
« on: April 10, 2007, 06:47:57 PM »
will they? cause i dont have the money for wheels now but i just put a 3in lift on and i need bigger tires
Offline Armour
  • 360
Re: Will 30x9.5-15 fit on my stock track wheels?
« Reply #1 on: April 10, 2007, 07:22:39 PM »
I would think there should be no problem. You can run a 12.50 on an 8 inch rim so why not 9.5 on a 7. I think that is what stock is.
Trackin92
« Reply #2 on: April 10, 2007, 07:47:19 PM »
im not sure but i am running 235's. How close are those to the size of 30x9.5??
Offline kirknd4spd
  • 333
« Reply #3 on: April 10, 2007, 10:52:38 PM »
yep, it will fit. there isnt much difference between a 235/75r15 and a 30x9.5
Offline museboy07
  • 641
« Reply #4 on: April 11, 2007, 04:14:57 AM »
30x9.5 are just a bit bigger then 235s right?
« Reply #5 on: April 11, 2007, 04:48:12 AM »
A 30 x 9.5" tyre should be on a 6.5" to 8.5" rim. It will probably fit on a stock rim ( 5 1/2") but I wouldn't advise it for road use. A 235 shouldn't be fitted on a stock rim either ( 6" to 7" rim needed). To be absolutely certain you should check with the tyre manufacturer as fittings can vary a little.
Offline bzzr2
  • 1011
« Reply #6 on: April 11, 2007, 10:46:00 AM »
i run 31x9.5's on my stock rims which are either 6 or 6.5 on the model i have, they work fine.  they'll just rub the frame a little when turning real sharp.
09 taco reg cab short box 4x4
Trackin92
« Reply #7 on: April 11, 2007, 11:21:16 AM »
yea my 235's are on 7" wide rims and I think they look pretty good on my Tracker on stock height. They stick out about 2" but it looks good like that. I plan on gettin 32's maybe just maybe 33's if i feel like spending more money lol
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #8 on: April 11, 2007, 11:26:34 AM »
hell im running 31x10.5's on 15x7's ;)
Trackin92
« Reply #9 on: April 11, 2007, 11:28:16 AM »
whatever works lol. When i eventually get my lift i want to get new rims preferrably 15x8's and I found some wheels i really liked by Dick Cepek I believe was the name of the company.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #10 on: April 13, 2007, 11:30:06 AM »
A co-worker has 30x9.5 BFG AT's on stock wheels and he has no problem.  The nice thing is that he can air down pretty far without risking losing a bead since the tire is on there tight.  The width is good inside the fenders too, if you're trying to keep it close to stock.
1993 4-door Sidekick
4.24:1 t-case
