WANTED: Spring Over Thoughts From You.
  • 15 Replies
  • 2225 Views
Offline Zukini
  • 18
  • It's not a Jeep thing, do YOU understand?!?
« on: April 05, 2007, 03:23:45 PM »
ok, hi eveyone. i have been registered on the site for a while now but untill recently had not been real active. i want to get some other opinions on what route to go for a spring over lift on my sami.
I am having a tough time deciding between Spidertrax kit, Sky's kit, or piecing one together on my own. i realize that the perches from sky are alot easier to use and i like that.
I am limited on my funds for this project but i want to do it right once. if i save money now but have to re-do stuff down the road, than its not economical. i know that alot of people on here have done the spring over. and almost everyone has learned something they would have done different had they known.
Any information you all have would be greatly appreciated.
Jeep boys hate it when the stock zuk has to come pull them off of a hill and then go right over it with no trouble at all.
Offline Amilla
  • 1076
Re: WANTED: Spring Over Thoughts From You.
« Reply #1 on: April 06, 2007, 08:18:42 AM »
how about peicing together a YJ lift?
just get hangers and some used springs, then go with some EZ weld spring perches, a drive line spacer and some break lines, some cheap shocks and some home made shackels.
its an idea...
Amilla
Offline Zukini
  • 18
« Reply #2 on: April 07, 2007, 01:21:23 PM »
hey amilla,
thanks for your input. i really appreciate any ideas at this point.
where would i go about getting the yj hangers and perches? sorry, just not something i have looked into yet.
Offline Amilla
  • 1076
« Reply #3 on: April 07, 2007, 01:47:50 PM »
Im going to get my YJ parts from http://www.trailtough.com/
just go to the "suspension components" category and the hangers, and shackles are all in there, then you can search for some springs to run, and get your shocks.
hope that helps out
Amilla
« Reply #4 on: April 08, 2007, 11:05:41 AM »
To be completley honest with you if you are limited on $$ why not stay spring under for now and do gears/lockers first? You may be suprised at what you can do with a well set up little sammy. Most of the guy's around here are doing just that now days. It took alot to convince me that little guy's could wheel good.
Offline Amilla
  • 1076
« Reply #5 on: April 08, 2007, 11:52:26 AM »
Ya man it makes perfect sence, you got nothing if you have lift, but no traction.
Amilla
Offline Element
  • 1902
  • LillyKicker
« Reply #6 on: April 08, 2007, 11:57:44 AM »
We just got back from Moab, wheelin with a stock height  tintop that had gears and locked front/rear! Did tipover challenge easily!!! Made some jeepers scratch their heads...
zUkTAH
U4WDA
« Reply #7 on: April 08, 2007, 07:32:56 PM »
Was it Dave Capel?
Offline Zukini
  • 18
« Reply #8 on: April 09, 2007, 08:59:44 PM »
i was thinking of a lift to clear the tires i have on it. they have no issues unless i flex it out to the max. then, they rub a bit. and that just drives me nuts. they are not huge, only like 30".
maybe i will consider lockers and maybe shackle it 2" to get my needed extra clearance.
thanks for your input. i will soon be on the look out for some gears and lockers soon.
speedball1981
« Reply #9 on: April 09, 2007, 09:48:00 PM »
yeah,  I wheeled a samurai with an add a leaf, lockers front and rear, and a calimini 4 to 1 t-case kitan 30 inch tires,  for like a year, and ran circles a stock sami with a spoa,  my only trouble was hangin my belly up alot,  but i never tipped over until I did the rocky road 5 inch spoa kit,  I have alot more flex now but i'm not really used to it yet i've tipped over like 6 times now,  but I like not rubbing my tires and i like the ground clearence,  hope that helps.
phloop
« Reply #10 on: April 10, 2007, 07:55:20 PM »
How about a body lift? You can get a 1" or 2" body lift from Sky. They are cheap, about $100 or so. Won't help with articulation but will give you some needed tire room. Or for the same price, a set of spring perchs will get you a ghetto spoa going. I've been running one of these lifts for the last 10 yrs, with driveline spacers and a dropped drag link. Of course, that ghetto lift is going to be trashed in favor of a Trailtough wangler spring swap. ;D
Offline Zukini
  • 18
« Reply #11 on: April 12, 2007, 07:28:57 PM »
thanks to all of you for your help. i am weighing all my options. i will hopefully have something done by the summer. i will let you all know when i do it.
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #12 on: April 12, 2007, 08:01:40 PM »
Zukini,
Here is my rig with 1 inches of lift (2 inch lift shackles) and 29 inch tires.
Locked in the rear did great. and was only about 350 for locker and shackles.
Did great that way, wheeled it on most of the trails at Evans creek WA, and Elbe hills wa never really had any problems.
Course here it is now. :P
Hope this helps.
If you want to see more stock wheeling picks let me know. :)
Mean Green Wheeling Machine
Offline mlovetripp0
  • 204
  • do more with less
« Reply #13 on: April 12, 2007, 08:13:58 PM »
before spoa with 27" tires
after spoa with 31" tires
to cheap to buy real steering for my spoa
please if you do it do it right
87 sammi
« Reply #14 on: April 14, 2007, 08:11:03 AM »
Hey Bash, nice to see you on the board again.  Missed you at the swap meet this year.  :)
