lifting a sidekick
  • 32 Replies
  • 6471 Views
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: lifting a sidekick
« Reply #15 on: April 03, 2007, 09:32:59 AM »
I have used Digger Spacers, they are top quality.
I am using BDS springs, struts and shocks... overpriced, but they work fine.
OME makes great springs and struts
and once again.  DOUBLE BLEH on body lifts..   ;D
« Reply #16 on: April 03, 2007, 12:50:40 PM »
are there any other front and rear coil springs that can be use on the sidekick other than the oems that will work good that any of you all know about or have tryed?  just wondering about that also what about a set off a 4 door kick would they be any better than a 2 door kick springs?
thanks rick.
GV springs are supposed to work well. Give around 2" of lift.
Offline jeff1997
  • 1228
  • 27
« Reply #17 on: April 03, 2007, 02:02:42 PM »
I'll sell you a set of 4 new 1.5" new coil spacers for $75 including shipping or 4 new 2" spacers for $90 including shipping. Look at them on ebay, seller:hoepkers. You can pay me with money order and I'll ship right away. Read some of my feedback, you won't be disappointed. E-mail me direct at hoepkers|removethispart|@charter.net to talk more about it.
3" Masterkit1 body lift
Custom strut spacers
Offline zukigroundpounder
  • 80
  • 3 trackers/kicks, 1 eclipse.
« Reply #18 on: April 03, 2007, 06:39:21 PM »
you  have   mail  and  pm.
Drive it like you stole it.
« Reply #19 on: April 05, 2007, 08:56:45 PM »
thanks rick.
I think ones off of the grand vitras give you lift too.
Offline olija
  • 770
    • Check out my cardomain
« Reply #20 on: April 05, 2007, 11:12:53 PM »
Jeep Grand Cherokee springs give about 3" of lift I believe.
  • 80
« Reply #21 on: April 06, 2007, 10:02:57 AM »
hello
thanks i did not know you could use the jeep springs. have you used them or anyone you know of use them? let me know i know where i can pick up some of these cheap.
thanks rick.
Offline brace
  • 264
  • I built it; I break it; I fix it.
« Reply #22 on: April 07, 2007, 04:11:09 AM »
 ??? I wish I would have seen this before I bought my 1 1/2 inch strut spacers for $60.    Does it matter what year Crown Vic for the rear shocks?  Do I still need to do a body lift to fit 31's?  I bought  the spacers from hoepkers on Ebay.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #23 on: April 07, 2007, 06:44:38 AM »
Dont want to spend alot, buy just the boondox 2.5 lift coils, or 3inch lift coils, and there strut spacers....   Rest is up to you.....
I bought the 4 door 3 inch lift springs, strut spacers... tossed them in my 2 door, sitting on 31x10.5's
Offline brace
  • 264
« Reply #24 on: April 07, 2007, 07:31:17 PM »
What shocks did you buy for the rear?
Offline Armour
  • 360
« Reply #25 on: April 07, 2007, 11:33:40 PM »
hello
thanks rick.
I am using jeep grand cherokee front springs in the rear of my tracker. They give approx. 6" of lift. Cut the little end off the top, they fit right in. Just have to make new pocket for the bottom. Nothing 3 1/2 " tubing and flat plate can't fix.
  • 80
« Reply #26 on: April 08, 2007, 08:16:45 AM »
hello
on the shocks if i remenber right i think they told me 91 vic shocks work real good. as for the jeep coils i pick up a set of those yesturday and going to go today and get some gv coils from a friend of mine and see if they will work. as for the coil spacers i have a friend that just made the coil spring prech on the rear and front 3" taller than the factory one on it they work great i'm planning on doing mine that way and then redoing the rear shock mounts to on the back.
thanks rick.
Offline Jookycola
  • 372
« Reply #27 on: April 08, 2007, 09:50:15 AM »
hello
thanks rick.
So what springs did you use for the front then?
  [/url]
Offline trackenator
  • 38
« Reply #28 on: April 19, 2007, 11:29:18 AM »
i have a 92 tracker 2dr. here is what i did. i have 2in heep spacers all the way around and a 3in home made body lift. i am now running 34x10.5 swamper ltb only a little trimming on the front fenders (i already trimmed bumper b4) its a 5spd 1.6  512 gears and moves them bid tires fine around town. i havent taken it off road but im sure tires would be hitting on something. also i just made 3in strut extenders today to put on my front end doesnt bounce at all even with new struts( i think they are on a bind /fully extended or something) just my 2cents worth.
  • 80
« Reply #29 on: April 21, 2007, 08:43:23 PM »
hello
the 3in strut extenders you made do you have Any pics of thema? i'd like to do thAt to mine in the front.
thanks rick
