GV aftermarket clutch
  • 2855 Views
Offline gv1600
  • 83
« on: March 30, 2007, 11:31:03 PM »
Hi all,
I own a 1600cc (16v) GV 2003 model with Manual Trans, factory 5,12's, and i want to replace the factory clutch with a better one.
I want to put Centerforce Dual Friction.
Anobody who has already putted the specific Clutch system yet?
Are there any differences from Vitara 16v to Grand Vitara 16v in order to fit that Centeroforce to GV?
What have you guys done to your cars ?
Thanks for any help! :)
Suzuki GV Calmini 2,5'' - Full Steel V6 Frond Diff - 205/80/16 KL71 -
4.24 t-case - T-Max 6500 - VTTR Snorkel - ProTrack Air-Lockers F/R
Offline gv1600
  • 83
Re: GV aftermarket clutch
« Reply #1 on: April 05, 2007, 10:22:47 AM »
Well,
Nobody tryied to replace his clutch with a Centerforce Dual Friction yet ?  ???
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #2 on: April 06, 2007, 12:40:22 PM »
I have a SPEC clutch sitting here (stage 3+, should be great for offroading), along with a new OEM Suzuki flywheel.  I bought it a few months ago when my clutch failed.  Turned out it was just the hydraulic part of the clutch that went.....so I'm waiting for my clutch to die, so I can have the SPEC installed.  I'm over 130,000 miles, and I'm running 31" tires, so it's just a matter of time before I replace the original clutch.  Centerforce doesn't make a clutch for the V6 Vitara/GV.  I called them.....and it's a typo in their catalog.
Dave
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Offline gv1600
  • 83
« Reply #3 on: April 06, 2007, 03:36:32 PM »
Hi Davyboy,
what kind is SPEC (stage 3+) ?  something better than Dual friction ?
in what car are you going to put the SPEC in?
Grand Vitara ?
Can you give me some details about SPEC please.......  i want to have some other options too.
How can i be sure that SPEC will fit to my GV ?
I dont want to change with factory again.
But also, take a look at this :
http://www.dragtimes.com/SUZUKI-VITARA-Centerforce-Clutches-m46-n307.html
Says that its for Vitara/GV with 1600 engine.....  And my GV is a 1600cc and not a V6.
Who knows...  ??? ???
Thanks for helping,
Vasilis.
« Last Edit: April 06, 2007, 03:48:33 PM by gv1600 »
Offline Davyboy
  • 252
« Reply #4 on: April 12, 2007, 09:10:50 PM »
Yeah....maybe you can get a centerforce for the 1.6 Liter.  But not for the 2.5 Vitara/Grand Vitara.  Here's a link to Spec Clutches:
http://www.specclutch.com
They custom make them in a few days for your application.  If you call them, and tell them what you want from your truck (offroad, dragracing, etc.) they will recommend Stage 1,2,3, etc.  They all have different characteristics.
Good luck.
Davyboy
Offline gv1600
  • 83
« Reply #5 on: April 13, 2007, 06:00:44 AM »
Hi,
i think i ll give it a try with Centerforce Dual and see whats going on.
Thanks for the info anyway 8)
Vasilis.
Offline gv1600
  • 83
« Reply #6 on: May 15, 2007, 12:30:09 PM »
Hi all,
i haven't much time to buy a Centerforce DF and try to fit it (if not ok, i had to sell it), so i finally got the factory/stock AISIN, which is good enough too.
Thanks for helping,
Vasilis.
« Last Edit: May 19, 2007, 11:13:19 AM by gv1600 »
