Anyone wheel with a 2wd kick?
  • 12 Replies
  • 2147 Views
Offline museboy07
  • 641
« on: March 27, 2007, 06:26:52 PM »
I am about to buy one and want to know if anyone has a 2wd that they wheel.  I was thinkin with a rear lock it shouldn't be to bad..any input??
Offline Armour
  • 360
Re: Anyone wheel with a 2wd kick?
« Reply #1 on: March 27, 2007, 07:11:14 PM »
I don't know anyone who has wheeled a 2wd but 4wds go pretty good in 2wd. and a locker always helps
Offline gravity_storm
  • 108
  • The wino and I know
« Reply #2 on: March 27, 2007, 07:41:11 PM »
I've been thinking that a 2wd with a locker would probably be pretty awesome for 90% of the offroading that I do. I'm keeping my eye out for a cheap one...
1996 Sidekick, 1.5" homegrown body lift, 2" Digger suspension lift, home made snorkle, front skid
Offline museboy07
  • 641
« Reply #3 on: March 27, 2007, 07:48:20 PM »
hell ya man..plus you can lift it without worrying about diff drop brackets and bad cv angles or none of that bullshit
Offline Yoak
  • 577
« Reply #4 on: March 27, 2007, 11:39:14 PM »
I did up untill recently.... :)
Offline goodyz
  • 133
  • Turdzuki.
« Reply #5 on: March 27, 2007, 11:39:49 PM »
Why not? just weld up that diff or throw a lunch-box locker in it and have some fun. I'd do it if I found a dirt cheap track/kick.
-goodyz
Offline goodyz
  • 133
  • Turdzuki.
« Reply #6 on: March 27, 2007, 11:41:02 PM »
I can vouch for that, I saw all the mud under that sucker! ;D
-goodyz
Offline Yoak
  • 577
« Reply #7 on: March 27, 2007, 11:44:28 PM »
Just washed it to.....the mud protects it from rusting! and its free too!
Offline kirknd4spd
  • 333
« Reply #8 on: March 28, 2007, 04:16:42 AM »
wheelin a 2wd would be fun. just put a mini spool in it, and have fun!  ;D
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« Reply #9 on: March 28, 2007, 04:36:46 PM »
Are there any problem with using a vehicle with locked differential on the road?.  90% of my driving will be commuting to work and around town.  Is turning affected?  I have drove tractors that you could lock the rear differential on and they did not turn very well.  Is there a cheap way to have a locker without it being locked all of the time.  Air lockers are out of my range.  How does a spool work?
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #10 on: March 28, 2007, 05:13:25 PM »
2wds can get around pretty good as long as the stay light and they have to be locked.
Here is some pics of one of our members 2wd in action.
http://www.rpm4x4.com/image.php?image=blake-jump-avf-2-02.jpg
http://www.rpm4x4.com/image.php?image=blake-jump-avf-02.jpg
Mike
Offline kirknd4spd
  • 333
« Reply #11 on: March 28, 2007, 10:09:53 PM »
basically, a mini spool replaces the spider gears in the diff, and locks the two axleshafts together, so both wheels always turn the same speed. its the same as welding a diff, but less likely to break stuff.
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #12 on: March 29, 2007, 04:05:55 AM »
I just relived my childhood watching the Dukes of Hazzard with those pics......man, he's flying!!!!!!!
  Did he get as much air as it looked like he did in the pics?
 :o
